Old 04-24-2019, 08:15 AM   #1
2015 30' FB FC Bunk
Thompsons Station , Tennessee
Low Point Leak
Our 2015 Flying Cloud sprung a pretty serious leak this week and wondering if its repairable without going to the dealer. It started as just a minor drip last week and then this week turned into a pretty serious spray. Any help would be greatly appreciated.
See my video of the leak below:
https://vimeo.com/user8080637/review...794/20d1f34d84
SmallStream is offline   Reply With Quote
Old 04-24-2019, 12:08 PM   #2
Kevin245's Avatar
It looks as though the ball valve NPT(F) section cracked. if so, this is an off the shelf item at many hardware stores and is readily replaceable by anyone handy with a wrench. If it were me I would change the valve and move on.
Eleanor Roosevelt
Old 04-24-2019, 02:11 PM   #3
2007 22' International CCD
Low Point Leak
You will have to unscrew the nut that holds the valve handle on and take the handle off to make it easier to unscrew the valve. Looks like it was either over tightened of freeze damage. Take it apart and also inspect the fitting the valve screws onto for cracks or damage.
Use two wrenches to take it apart. One to steady the fitting the other to unscrew the valve. Use white Teflon tape as thread sealant to put it back together.
Turn off the pump and disconnect city water before you try to get it apart.
Itís a standard valve from any big box or hardware store.
Old 04-24-2019, 06:32 PM   #4
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Welcome Aboard....👍
What Rich said...Turn the pump off.🤔
Amazon is your fiend,😂
W. H. Auden
"The hardest thing about Airstreaming, clearing your head and accepting how others feel itís supposed to be done"Ö..
Amanamus
"Tahawus"
Old 04-24-2019, 08:55 PM   #5
Oh, Bob, your spellcheck got it right this time. At least thatís my experience with all the goodies available on my fiend, Amazon.
Old 04-25-2019, 12:26 AM   #6
2015 30' FB FC Bunk
Gentlemen,
I’m amazed by this community yet again. You saved me $100s of dollars and a few days waiting for the dealer to fit me in. Found a $7.50 part at Home Depot and I’m good to go. I will say that removing the bad valve was pretty difficult as the little arm stopped it from fully rotating as it sits out too far. It had to be removed and even then the valve slightly scratched up the bottom of the airstream. But it’s working! Thank you!
Old 04-25-2019, 01:08 AM   #7
Long Island , New York
Glad it worked out, SS.
Leak > above 2 low point drains Too tall Plumbing - Systems & Fixtures 8 02-03-2018 03:45 PM
Low Point Drain Valve Leak RonMcMusic General Repair Forum 13 09-30-2017 05:46 PM
Point A to Point B travel time limits LakeState On The Road... 46 03-25-2015 01:03 PM
Low point valve leak john4170 Fresh Water Systems 2 08-29-2014 01:17 PM
Failure of low point drain valve? desidou Fresh Water Systems 8 12-24-2006 08:29 AM
