Old 08-02-2008, 07:07 AM   #1
rec
1989 29' Excella
anywhere USA , full-timers traveling the country
looking for tank monitor replacement parts
we have a 1989 excella and there is something wrong with the board in the panel behind the buttons for monitoring the levels in the water and waste tanks -- the rest of the monitor works fine (the part that has the range exhaust vent, the light, the water pump switch) -- it's just something bad behind the one side of the panel.
We went to the Airstream service center in Jackson Center, but they didn't have a part to repair it because the monitor is so old -- but they did say that if we could find the part elsewhere, they could repair it. Would anyone out there happen to have or know where to find the right model tank monitor -- even if part of it is broken or banged up -- just for parts? Or does anyone know someone who specializes in finding the parts to fix these old monitors? I hate the thought of having to replace the whole dadgum thing -- when all we need is one little board Thanks!
rec is offline   Reply With Quote
Old 08-02-2008, 09:01 AM   #2
You don't need a new board.
If I remember correctly, that board has some transistors in it.
Find a electronics repair shop, who can easily ID the defective transistor, and have them replace it.
That will put you back in business, without the need to spend a ton of money.
Old 08-04-2008, 07:37 AM   #3
rec
1989 29' Excella
thanks!
wonderful -- we'll give it a try -- so I would just unscrew the panel, remove the board, and take it with me? Thanks so much!
Old 08-04-2008, 08:18 AM   #4
That's all there is to it.
Somewhere I had the numbers of the transistors that were used, but, I cannot locate it.
Sorry.
Micro Pulse Tank monitor calibration Silvertwinkie Plumbing - Systems & Fixtures 98 11-03-2014 01:09 PM
brake replacement parts watt1968 Brakes & Brake Controllers 5 07-03-2008 07:17 AM
Replacement Parts for Rockguard? tslanier Windows & Screens 2 07-15-2006 07:38 PM
Exterior replacement parts Kandy Ribs, Skins & Rivets 2 06-22-2006 09:40 AM
Tank Monitor Help pmclemore Electrical - Systems, Generators, Batteries & Solar 4 01-31-2006 12:41 PM
