Old 10-05-2016, 03:40 PM   #1
1974 Argosy 26
Joshua Tree , California
Lock on Fresh water fill door
When I bought our '74 Argosy 26' it came with all the keys save one: that for the the fresh water fill door at the front of the coach. Just had the locksmith over and he was able to pick the lock. The only way to remove the lock (to examine and make a key) is to unrivet the lock unit from skin - possibly unrivet skin. The door is a Thetford product. The locksmith can impression the key but It would help to narrow down what is the correct blank. Several questions arise: 1. Has anyone else faced this issue and what have you done? 2. Can one or several of y'all post a picture of your key from the appropriate era? It will be a small double-sided key (teeth in both sides)? Thanks!
StarckMad is offline   Reply With Quote
Old 10-05-2016, 03:53 PM   #2
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
Can you post a picture of your lock assembly?
Old 10-05-2016, 03:54 PM   #3
retired USA/USAF
2001 30' Excella
Somerset , New Jersey
I think you'll find these to be a common key through the RV industry and certainly within Airstream. I'm not sure which key it is on the ring I have here. The one I keep at my trailer is stamped so I can ID it. Sorry. Someone here will confirm it, I'm sure.
You should be able to order one.
I don't know how to include an attachment here but google Airstream Water fill key and you should find it. It says G248 was used for water fill in 1974.
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
polarlyse is offline   Reply With Quote
Can water heater fill from fresh water tank? phann Water Heaters, Filters & Pumps 11 05-21-2015 03:07 PM
Stainless Steel Fresh Water Fill Door Al - K4GLU Airstream Lifestyle 3 10-31-2013 11:25 AM
1964 fresh water tank fill cap lock Safari64 Fresh Water Systems 0 06-25-2013 01:30 AM
key for the Thetford lock on water fill door batt Doors & Locks 1 04-11-2012 08:22 PM
I can't lock the 'Water Tank Fill door' memgrove2000 Fresh Water Systems 6 07-04-2009 06:35 AM
