Old 08-17-2014, 04:58 PM   #1
Robfromnorth's Avatar
1973 25' Tradewind
Calgary , Alberta
Let's play what is this.
I am in the midst if a full year down and rebuild of a 73 Tradewind.
The plumbing lines were all ruptured from freezing at some point but the last owner installed a water pump and I have a couple of questions about what I am seeing. The pump looks like it's in decent shape and so I'm holding on to it. But what is (and should I keep) this thing attached to it?
Also. Why is there springs in these lines connected to the pump.
Thanks in advance for taking a look and sharing what you know.
Name:	ImageUploadedByAirstream Forums1408316260.133058.jpg
ID:	219248Click image for larger version
Name:	ImageUploadedByAirstream Forums1408316270.373678.jpg
ID:	219249Click image for larger version
Name:	ImageUploadedByAirstream Forums1408316279.373530.jpg
Robfromnorth is offline   Reply With Quote
Old 08-17-2014, 05:04 PM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Yikes, looks like someone made a trip to Lowes, grabbed a bunch of parts of the closest shelf and screwed them together.
MICHAEL
Old 08-17-2014, 05:06 PM   #3
1973 25' Tradewind
Calgary , Alberta
Yeah. That's pretty close.
I am sure the brass piece is a pressure regulator but it has a black gunky residue. Click image for larger version
Name:	ImageUploadedByAirstream Forums1408316766.379075.jpg
Old 08-17-2014, 05:07 PM   #4
1976 31' Sovereign
Oswego , Illinois
The springs keep hose from kinking or collapsing, if replacing hose insert springs into new hose, other ques. I don't what it is.
Old 08-17-2014, 05:10 PM   #5
r carl's Avatar
Lin , Ne
Its the switch that turns off the pump when the pressure is built up. The spring is in the suction hose so it doesn't collapse.
Old 08-17-2014, 05:46 PM   #6
1994 34' Excella
Warren , Manitoba
It is a pressure switch, commonly used on rural house pressure systems, to control the well pump shutting off with high pressure, and turning on when taps are opened and the pressure drops. I have no idea why it is there, unless, the pump that you have has no built in pressure control. If so it is not designed for an RV. It looks like the previous owner was related to McGiver.
CBWELL is offline   Reply With Quote
Old 08-17-2014, 05:56 PM   #7
1973 25' Tradewind
Calgary , Alberta
The spring in the hose seems like an over-design. There must be a better and easier way.
Old 08-17-2014, 06:21 PM   #8
RM66caravel's Avatar
1966 17' Caravel
Newport , North Carolina
A. A pressure regulator for the water pump!
B. hydro coupler for the inertia damper preventing you from flying back against the wall when increasing speed from impulse to warp!
Cliff
Gotta get busy! Have a great day! Now where did I put those revits?
RM66caravel is offline   Reply With Quote
Old 08-17-2014, 06:23 PM   #9
1973 25' Tradewind
Calgary , Alberta
I'll take B anyday. I'm still using a suspended dampening coil system for inertia displacement. You know how hack and patch the 70s models are.
Old 08-17-2014, 06:28 PM   #10
1987 25' Sovereign
Oregon , Ohio
Cliff
Thank you Scotty, or is it Mr. LaForge
msmcv51 is offline   Reply With Quote
Old 08-17-2014, 06:30 PM   #11
RacerX's Avatar
1964 22' Safari
Walnut Creek , California
Images: 8
Was the PO "Macgyver?" While I'm sure it works, it might make sense to swap that whole setup out with a known RV water pump. It seems to me like SHURflo is the brand you would find in most RV camping stores.
Mark, Norby, Nicci and (occasionally) Matt
"The reward for work well done is the opportunity to do more." Jonas Salk
RacerX is offline   Reply With Quote
Old 08-17-2014, 08:13 PM   #12
aquinob's Avatar
Portsmouth , Virginia
Is the whole thing plumbed in with rubber hose? Don't think I would care for that, can affect the taste of the water. I'd think about replacing it with PEX. What is the rest of the trailer plumbed with?
Ongoing adventures at:
http://1973overlander.blogspot.com/
aquinob is offline   Reply With Quote
Old 08-18-2014, 02:58 PM   #13
1973 25' Tradewind
Calgary , Alberta
I am replacing all the water lines and drains. I think I'll start a thread on the whole shamozzle, but the short of it is that every copper water line had a break from freezing and the main grey tank drain was broken off the tank and drained into the belly for... Who knows how long.
Let's Play: "Can You Name That Opening " !! Aktundra Exterior Storage Compartments & Access Doors 2 05-31-2014 10:52 PM
How to play ebay? maxandgeorgia Off Topic Forum 46 03-10-2007 07:42 PM
solar pro plug and play 75 ardenrj Generators & Solar Power 0 03-20-2005 09:43 PM
PDX area? Come see our play! Stefrobrts Off Topic Forum 7 10-26-2004 09:29 AM
