I am hoping someone can help us with the following questions.
We took our 1970 Overlander on an trial trip. During the trip we stayed at 2 TX state parks, and hooked to the park water system. Well, it seems the trailer had developed a few leaks. One was under the kitchen sink on the cold water side of the winterizing valve, and the other one is located, (how to put this), where the rear hatch door is (where you run your electric and sewer out of). There is a rubber hose that is located here and clear water was running out.
On the first leak I think the cause may be caused by not having a water pressure regulator installed, and the high pressure is forcing water through the drain lines. On the second leak (I'm not sure where this line is coming from) but maybe it's the drain line for the hot water heater(?) and the air pocket is gone and high water pressure is forcing water through the water heater?
If I'm anywhere near correct in my ramblings, please reply, or let me know what ya'll think.
Patsyj1, I wish I had some answers. My experience with water line leaks is limited to problems with winterizing. But since I don't have answers I'm bumping your thread back to the top. Maybe someone out there can help.
BTW, I see this is your first post. Welcome to the forums! I hope you find the help you need.
Sounds like the winterizing valve was not closed. Valves and the system should handle just about any pressure you can put to them, assuming 100 PSI or lower, UNLESS the there is a breach in the line somewhere. Often, copper lines that have cracked due to freeze damage have been repaired by cutting the bad section out and using automotive heater hose as a splice between the two pieces of copper. This will come back and haunt you when you least expect it.
The water heater has a valve for draining it behind the cover on the exterior of the coach.
CP 9 miles off Exit 399, I75.
Propane Powered Honda EU2000i
Lots of Hot Sauce! Air # 283
On my trailer the leak was under the sink. All it was a loose conection on the cold water to the sink. Our trailer also has 2 drain valves by the the dump valves. I also have a pressure regulator on the trailer and on the hose. I know it is a over kill but I have been to camp ground with a lot of pressure.
My advice is hook up the hose and turn it on and start looking .
The rubber hose should not be there. In my trailer it is all plastic connections.
I hope this will help.
Hi all: This is an old thread but it is appropriate for my question. We were in Morro Bay and hooked up to city water. My regular water regulator was attached to the hose where it connects to the A/S. I noticed water dripping from two separate locations behind the wheels just up from where the white water release valve is located. As best as I can describe it was leaking somewhere between the city water connection but before the regular water holding tank (which was completely full by the way).
The trailer is a 2006 28 foot Safari SE LS.
Still under warranty, but wanted the board thoughts.
