Old 08-25-2014, 03:22 PM   #1
1978 31' Sovereign
1988 32' Excella
Linthicum , Maryland
Leaking waterfilter - how to detatch water in/out?
Hi - waterfilter is leaking (broken glass in filterholder)-needs to be replaced. Unfortunately, there is no indication as to what type of filter this is and prev. owner installed unmarked filter. This is not the problem. My problem is to disconnect the water in/out of filter housing. Waterlines are new type, crimped onto connectors and there is no way to unscrew the 90 deg bend used. So - how do I proceed and unhook the crimped waterlines? Cannot upload pics - as service is unavailable, sri.
Any advice would be helpful.
RuneM46 is offline   Reply With Quote
Old 08-26-2014, 05:31 AM   #2
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
I don't believe there's any good way to uncrimp a crimped connection. I suggest you cut the lines close to the crimps, and plan on going back with some other sort of connection, either threaded or barb-and-clamp.
Anyone else out there have a better idea?
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 08-26-2014, 06:03 AM   #3
1978 31' Sovereign
1988 32' Excella
Thanks Protagonist - Guess there is no other way than to grab the Hack-Saw and cut line(s) by the 90 elbows, thus getting to the lines and unscrew the elbows.
Old 08-27-2014, 08:53 AM   #4
1978 31' Sovereign
1988 32' Excella
Got a new filter and replaced the old one. Got water into the new filter, but nothimg in the faucets. All valves are open - still nothing. I am lost here. Btw the water pump looks brand new. Should be self priming.
Old 08-28-2014, 08:28 AM   #5
1978 31' Sovereign
1988 32' Excella
New thought - after looking at the print for the water system, I started wondering - what if the filter was mounted backwards? Assume there is some sort of "flap-valve" inside the filter. So mounted backwards means no water in the faucets, right?
Old 08-28-2014, 08:48 AM   #6
Wayward's Avatar
Cary , North Carolina
Cut the pex line close to the fitting and then split the old ring.
SARGENTŪ Copper Pex Crimp Ring Remover - YouTube
2006 Safari SE FB
2000 F150 4.2L
2011 F250 6.2L
Broadway, NC
Leaking new out of the box Jr1974 General Repair Forum 27 06-02-2012 01:06 PM
???Battery, waterfilter, '04 Bambi... crazylev Electrical - Systems, Generators, Batteries & Solar 5 01-16-2005 11:34 AM
Winterizing and Waterfilter overlander76 Winterizing, Storage, Carports & Covers 12 10-21-2004 09:59 PM
Water Heater Leaking Outside overlander76 Water Heaters, Filters & Pumps 8 11-02-2003 03:11 PM
HELP fresh water tank leaking wvabeer Fresh Water Systems 2 04-08-2003 11:10 AM
