Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures
Old 08-29-2005, 02:59 PM   #1
Gene Wissink
Profile:
Leaking valve
I have a valve in the back that is hooked to nothing that I can see. It comes off a T with a handleless shut off, it looks like I will need a one inch screw driver to back it off, with a flare cap on the end. the leak is past the threads, will pipe dope fix this problem? What is this valve for?
Gene Wissink is offline   Reply With Quote
Old 08-29-2005, 03:26 PM   #2
Anon
Profile:
Is this for the grey water or black water tanks?
Are they big valves?
I guess what I want to know is what type of plumbing is it hooked to? Freshwater or dirty water?
Anon is offline   Reply With Quote
Old 08-29-2005, 05:35 PM   #3
Gene Wissink
Profile:
leaky valve
My wife always says that do not tell the whole story, so here goes. The valve is on the city fresh water inlet piping, 1/2" copper, it goes, city - preasure regulator - check valve and this valve that is leaking. and then a T for the rest of the cold water piping.
76 soverign
Old 08-29-2005, 05:48 PM   #4
overlander63
overlander63's Avatar
Profile:  1974 31' Sovereign
all over , Fulltiming
Images: 58
76 soverign
Sounds like a winterizing valve. If you open it while under city water pressure, does water gush out on the ground under the trailer? If so, that is what you have. It can be easily replaced with a few commonly available plumbing tools.
Change is inevitable, except from a vending machine
AIR#2611
Old 08-29-2005, 06:34 PM   #5
john hd
john hd's Avatar
Profile:  1992 29' Excella
madison , Wisconsin
Images: 40
pressure pop off relief valve?
commonly capped when they leak.
john
you call them ferrets, i call them weasels.
Old 08-29-2005, 08:11 PM   #6
Gene Wissink
Profile:
I have two drain valves with handles on them, there is no handle on this one, just a countersunk screw down center part with a indent in the center with screwdriver slots on either side of the indent, I can not get my head in to see what is in the indent. I have not used city water for a hookup. I think it is some place you can hook to another line to without shuting down the water supply.
Old 08-29-2005, 08:38 PM   #7
jsmith351
Profile:  1976 31' Sovereign
1961 19' Globetrotter
Phoenix , Arizona
I have the same model and just completed re-plumbing last week. Sounds like the check valve, on mine it has '60' stamped on the top. Do you have a digital camera?
jsmith351 is offline   Reply With Quote
Old 08-30-2005, 06:48 AM   #8
Gene Wissink
Profile:
Got to take picture of this thing. Our unit is out in the timber used as our hideaway when we want to get out of town and toilet for the farm. The leak did not show up until I changed water pumps, maybe it is a relief valve that one of the PO's capped off because it leaked, I am going to put a preasure gauge on the line and see what I have. The check valve is the 1/2" inline type
Old 08-30-2005, 07:44 PM   #9
Gene Wissink
Profile:
We took some pictures today, will put them on line as soon as we can. I took off the flare cap and put on a piece of garden hose off the fitting so at least the plywood will dry up, as soon as I took the cap off the fitting the water stopped coming out of the top and came out of the hose.
Old 08-30-2005, 08:00 PM   #10
Anon
Profile:
Let us know when you post the pics.
I hope we can help!
Old 08-30-2005, 08:36 PM   #11
Gene Wissink
Profile:
Jsmith351
How far did you go on your replumb job? The city water comes in on a tear drop L to another L then preasure regulator with adjusting screw on top, L, screw in 1/2" check valve, L, 8" pope, L, L, T with this valve on it, more copper pipe, T to rest of the system. I am thinking that might it be a redo from past PO's
Old 08-31-2005, 10:05 PM   #12
jsmith351
Phoenix , Arizona
I replumbed the entire coach. The manifold you are referrencing, I rebuilt in PVC. I still have the copper manifold intact with exception to check valve and pressure regulator. I'll see if I can snap a shot tomorrow night and post for ya.
Jason
Thetford valve rebuild mkeith54 Waste Systems, Tanks & Totes 17 10-15-2007 02:37 PM
Black & Grey valve trouble camphost Waste Systems, Tanks & Totes 51 08-18-2006 08:45 AM
Dump Valve Rebuild wagsrp Waste Systems, Tanks & Totes 2 10-12-2002 01:01 PM
Fixed that dump valve !!! 77caravaner Waste Systems, Tanks & Totes 0 10-02-2002 07:28 PM
city water inlet valve failure? JohnGalt48 Fresh Water Systems 2 08-01-2002 04:43 PM
