Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures
Old 07-24-2009, 10:55 AM   #1
Profile:  1977 27' Overlander
Rockville , Maryland
"leaking pipe" problem or nightmare?
The current owner of an AS I'm buying (70's 25' TradeWind) tells me there is a pipe problem under the floor of the bathroom, which he has never used.
Am I going to have to dismantle the entire bathroom and/or interior to get at it? Is there a way to diagnose the problem first?
Any advice much appreciated!
md
doctormark is offline   Reply With Quote
Old 07-24-2009, 11:12 AM   #2
Lumatic's Avatar
Profile:  1971 25' Tradewind
Estancia , New Mexico
What year Tradewind?
Some of the plumbing is visible, some enclosed by the bathroom furniture. The water lines are above the floor level. The drain lines are below the floor.
If the PO is right about the problem being below the floor it is probably a loose shower P trap. There may be a squarish access point in the belly pan. Anyway, the good news is if the problem is a drain problem you can cut out a section or drop the belly pan without taking out the bathroom. If the problem is a leaking supply line you can probably add a replacement line without a complete dissassembly too. Also check your roof vents are not clogged up. That can also cause leaks down below.
To diagnose: Put on some grubby clothes and hook up the system and try her out. See where it leaks from. If you get a leak through the belly pan but the floor is dry in the trailer it's a drain line leak, leaking black water or grey water tank or dump valve leak. If you have a wet floor it's a supply line. Keep in mind where the water comes out of the belly pan may be a couple of feet away from the leak source. You could also use an air line and listen for a leak for supply lines.
Pay no attention to the man behind the curtain- WoZ
Old 07-24-2009, 11:15 AM   #3
HowieE's Avatar
Profile:  1991 34' Excella
Princeton , New Jersey
Images: 11
Take an ice pick and poke around. If there is a rug your will poke through it but if the floor is good the pick should stop there. You may find areas that you FALL through and areas that are SOFT. In either case those are areas that have to be addressed.
If you find a soft spot don't stop testing at the wall or door. Rot does not stop at partitions that are above the floor.
He said a pipe problem below the floor. There should not be any pipe, other than sewer, under the floor. It is unlikely that the sewer system would fail in such a way as to cause a problem in the floor. The one exception is the point where the toilet is bolted down to the floor.
WBCCI 12156 AIR 3144 WDC unit
1997 6.5 Diesel Chevy 2500 See my pages mysite.verizon.net/vze54tx9/
and mysite.verizon.net/vze54tx9/kayak/
1991 34 ft. Excello +110,000 miles, new laminated flooring, new upholstery, new 3200 lbs axles
Old 07-24-2009, 02:32 PM   #4
jkcru's Avatar
Profile:  2010 28' Flying Cloud
Escondido , California
You could drop the belly pan under that area to check.
jkcru is offline   Reply With Quote
Old 07-24-2009, 03:26 PM   #5
mello mike's Avatar
Profile:  1972 31' Sovereign
Phoenix , Arizona
Images: 14
md
Lumatic gave you some excellent pointers. More than likely, you won't need to take anything apart. If the drain/vent ABS pipes or water lines are leaking, you may need to remove a bathroom piece or two to gain access. My bathroom comes in 8 pieces.
My bathroom is completely torn apart right now after having a new subfloor installed. This weekend I'll be installing new flooring, re-installing the drain/vent pipes, and reassembling the bathroom.
Sterling - 1972 Sovereign Intl (RB)
Eddie - 2003 Ford Excursion (6.0L PSD)
Prodigy Brake Controller / Equal-i-zer Hitch / Honda EU2000i x2
Airstream Life Contributor
WBCCI 4CU #5661/AIR #5661
My Refurb Blog: UPDATED!!
http://mellomikesairstreams.blogspot.com/
Part wanted: 70s Kitchen Counter Unit
mello mike is online now   Reply With Quote
Power problem indicated by "weak" microwave? davida Batteries, Univolts, Converters & Inverters 4 06-12-2007 02:23 PM
Power steering problem on my "NEW" 345 JBK Mechanics Corner - Engines, Transmission & More... 19 10-23-2006 09:54 AM
Silly Dometic refrigerator "problem" Toasty's Dad Refrigerators 0 12-20-2005 08:19 PM
