Old 10-14-2008, 10:30 AM   #1
99Limited34's Avatar
1999 34' Limited
Darien , Wisconsin
Leaking kitchen faucet
I have a 1999-34 foot Limited that has Moen single-handle kitchen faucet that leaks, the leak is getting progrssively worse and is quite irriatiting. I tried to get to the cartridge, removed the cap and there's a screw that holds the handle on, the screw will just turn and turn, but won't come out. Looked under the sink to see if there were nuts that hold the faucet to the counter and can't find a thing..
Does anyone have any ideas how to get to the cartridge or remove the entire faucet so that a new one can be installed?
99Limited34 is offline   Reply With Quote
Old 10-14-2008, 10:48 AM   #2
easyride's Avatar
1977 27' Overlander
1963 19' Globetrotter
Naples , Florida
Have you looked in the center,where the water lines enter,should be a big nut there holding faucet on.As far as getting the screw out ,if it keeps turning then there is a plastic piece broken under the cap that should prevent it from turning.Only option is break away the piece the screw is holding ,then hold stem with needle nose and take out screw.Moen warranty #1-800-289-6636 they should send you all parts you need,except maybe the puller,you can usuallly get that as a borrow tool at Ace Hardware, after leaving a deposit. Dave
easyride is offline   Reply With Quote
Old 10-14-2008, 11:10 AM   #3
DEITZ645's Avatar
2006 30' Classic S/O
Mohrsville , Pennsylvania
99limited34,
Take a look at these links from the Moen site, they should help as it is the same basic construction as the old one in your trailer...
Exploded Parts View
Instruction Sheet / Owners Manual
They are pretty simple once you get the handle off...Famous last words.
Carl, Elaine & Finn The Beagle
2006 30' Classic W Slide & Limited Package Katarina
2006 GMC 2500 HD 6.6 Turbo Diesel Crew Cab 8' Bed
TAC PA-3
S/OS#042
AIR #14487
NQ3U (was KB3UOM)
DEITZ645 is offline   Reply With Quote
Old 10-14-2008, 03:00 PM   #4
1999 34' Limited
Darien , Wisconsin
Thanks for the help...Have taken the whole faucet off and have a brand new one to put in its place..
Old 10-17-2008, 10:35 AM   #5
cammur's Avatar
Roseville , California
I've had a similar problem but it actually turned out to be the circular decorative flange - it worked its way loose (it threads) enough to keep the control lever from fully lowering.
This is a recurring problem - I just have to twist it back down when it happens.
Cam
2005 25' Safari SS
2005 Dodge Ram 2500 Turbodiesel
WBCCI #3580 - Region 12 NorCal
AIR #8752
Roseville, CA
cammur is offline   Reply With Quote
Kitchen Faucet Repair carnegie1935 Fresh Water Systems 14 01-17-2009 07:31 PM
kitchen faucet Beverly II Interior Restoration Forum 4 08-12-2008 12:04 PM
Replacing kitchen faucet Sovereign86 Sinks, Showers & Toilets 5 09-13-2007 06:57 PM
Kitchen Faucet Repair hhessig Sinks, Showers & Toilets 2 05-23-2006 03:16 PM
kitchen faucet leaking Stefrobrts Fresh Water Systems 10 03-16-2004 09:44 AM
