Old 04-09-2018, 06:26 PM   #1
Boise , Idaho
Leak on around the City Input / Flush input
2016 25' International FB. This morning I noticed a small leak / drip from the outside shore side near the wheel well. At first I thought it was the drain tubes but the AC had not been running. As I looked closer it was coming out from the exterior rub rail. I looked inside below the closet from the heater duct. I noticed a small drip on a PEX elbow and some water spots coming down the shell wall that seemed to be old and have occurred before as it looked old. Plus some of the insulation seemed wet. I ruled out condensation.
Once we reached our next spot. I took the panel out in the closet. It looks like possibly the city water inlet has been dripping on the lower black tank flush outlet. The PEX copper crimps both have corrosion / patina which I would expect if they have been hit will water some. The upper elbow was a little loose. I was able to hand tighten it. I am not sure that was it though.
What has me questioning if that was it is we rarely use city water since we mostly boondock. The flush valve was used a few days prior and the connection was not solid I guess some water could have sprayed in?
Ironically we are hooked to city water at the moment. So far no drips.
Anything else I should be looking for?
wponder is offline   Reply With Quote
Old 04-09-2018, 06:29 PM   #2
Full time Airstreamer
SCOTTinNJ's Avatar
2014 30' FB FC Bunk
Anywhere , USA Living.Somewhere.Yonder
The connection from the city water inlet to the internal plumbing is not supposed to be rigid pipe. It bends the city water inlet. Had to replace mine with similar symptoms.
@living.somewhere.yonder | Instagram
SCOTTinNJ is offline   Reply With Quote
Old 04-09-2018, 06:31 PM   #3
SCOTTinNJ's Avatar
2014 30' FB FC Bunk
With the curved shell it doesn't sit flush.
ID:	308305Click image for larger version
Once and for all--need to blow out City Inlet and Black Flush? pcskier Winterizing, Storage, Carports & Covers 27 11-30-2016 11:38 PM
water dripping from city water hose attachment location when NOT hooked up to city wa Wilmington Plumbing - Systems & Fixtures 1 03-19-2012 09:25 PM
My toilet won't flush on city water godaddy64 Plumbing - Systems & Fixtures 12 09-18-2011 02:37 PM
Thetford flush valve leak 66Overlander Fresh Water Systems 17 04-10-2011 09:11 AM
Hooked hose to flush valve instead of city water... Denis4x4 Waste Systems, Tanks & Totes 9 09-25-2007 09:50 AM
