Old 06-24-2003, 02:54 PM   #1
stuart1's Avatar
Krylon "fusion"
Hello All. The tub to our shower has colored with age and I'm really tempted to use a new paint that Krylon has come out with. It's the "Fusion" line and is made specifically for plastic, even has the right color.
Has anyone used it before? Your input would help. Thanks..Sturt
Tuey
stuart1 is offline   Reply With Quote
Old 06-24-2003, 04:56 PM   #2
LOST , Hawaii
Used some today on my sunvisors, it covers well. My only concern would be how well it would stand up to water and underfoot.
John
74Argosy24MH is offline   Reply With Quote
Old 06-24-2003, 09:36 PM   #3
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
Krylon "fusion"
Greetings Stuart!
I would have reservations about using the Krylon "Fusion" product on a shower or tub as its high gloss might lead to excess slipperiness. There are a number of two-part epoxies that can be utilized for the ABS and fiberglass elements found in the bath fixtures in your Airstream. The difficulty can be in identifying them - - a knowledgeable Airstream dealer or customer support at Airstream may be able to clarify what was used in each. The professional who redid my bath fixtures was able to identify the products by testing with various chemicals that he had. For the bath, he had to use three different primer/surfacers as well as three different top coats due to the three different kinds of plastics and fiberglass found in my '64 Overlander.
So far, after the first two trips, the refinished bath is absolutely delightful. A photo of the before is below:
The after photo is below:
Good luck with your refinishing project!
Kevin
Kevin D. Allen
AIR #827
