Old 04-30-2016, 08:07 AM   #29
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
You can use stainless or brass wool to stuff the holes during the warmer weather... just be sure to remember to remove before using the heater.
those squiggly dish scrubby thingies could work as well. Just don't use steel wool as it will rust and leave a mess behind!
Old 04-30-2016, 08:10 AM   #30
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Originally Posted by AtomicNo13 View Post
You can use stainless or brass wool to stuff the holes during g the warmer weather... just be sure to remember to remove before using the heater.
Duck tape over the holes also works, and keeps water out of the furnace when you wash the Airstream as well.
WBCCI #1105
My Google-Fu is strong today.
Old 05-04-2016, 01:38 PM   #31
Plasma800's Avatar
houston , Texas
my overall furnace dimension out side is around 20 wide x 11 tall
'15 27fb Signature
'12 Chevy 2500HD Gasser
Plasma800 is offline   Reply With Quote
Old 08-29-2016, 04:56 AM   #32
Goliad , Texas
Originally Posted by perryg114 View Post
The screen is a necessity in the south. Air flow to the burner will really get messed up when it is blocked or caked with mud. Take it off when you are using the furnace if it offends someone. I had to replace my furnace and one of the issues was all the mess that wasps made. I am an Aerospace engineer and these screens are not going to cause problems with air flow. The wasps will DEFINITELY cause problems.
Heard that......screens on every opening a dirt dauber can get into. Down here when it rains they will build one of their mud huts on a board before you can nail it up. Seriously, seen it happen. No kiddin'.
The Frommes
Goliad, Texas
The Birth Place of S. Texas Ranching
WBCCI #6256
eartick is offline   Reply With Quote
Old 08-31-2016, 04:56 PM   #33
2016 30' Classic
Rocklin , California
I installed the stainless steel screen on the furnace exhaust to keep the wasps out of my 2016 Classic. It Works great.
Unfortunately, I cannot find one to protect my Truma instant water heater. I called Truma and the young lady thought my inquiry into the possibility of obtaining a screen to cover the intake vent was odd and had never heard of such a thing.
Any ideas folks?
Gamehawkers is offline   Reply With Quote
Old 09-08-2016, 09:34 AM   #34
1981 31' Excella II
New Market , Alabama
Maybe you can adapt something. My Atwood wh is open enough you can at least hose the flue out or knock out the nest with a screw driver or something.
Old 09-08-2016, 10:03 AM   #35
Boxite's Avatar
2008 22' Sport
I've had good results with the RV accy's screens such as AWCHIEF posted...but I'd make a recommendation.... Use clear plastic tubing (1/4" works) to split down it's side and slip onto the base of the screen to prevent the screen from chafeing the side of your airstream's aluminum/clearcoat.
2012 Ram 1500 Crew Cab 4.7L 4X4
Old 09-08-2016, 01:19 PM   #36
DaveFL's Avatar
2000 31' Land Yacht
Central , Florida
Furnace used so seldom it would be hard to remember to remove anything stuffed in.
Old aluminum screens re-purposed for vents, should be oversize for tube to allow air to flow freely..
Stainless scrub pads not a good idea, due to rust and brass scrubbers need to be checked with a magnet, found the last batch of brass rusted like the stainless it was replacing.
Old 10-05-2016, 09:04 PM   #37
Mike1997's Avatar
1998 36' Land Yacht Widebody
Ft. Lauderdale , Florida
Images: 14
Camping World has several different sizes of wire mesh screens for water heaters, furnaces, and frig vents. I kept getting all sorts of bugs in the frig compartment outside. Put the 3 mesh screens on the bottom openings and its great. Water heater has one that sticks out somewhat but its not very noticeable and works great too.
Mike1997 is offline   Reply With Quote
Old 10-06-2016, 04:32 AM   #38
paiceman's Avatar
Upper St Clair , Pennsylvania
I use the blue painters tape on the inside of the screens. No issue taking off, no residue and never had wasps or anything else get in.
2017 30' Classic - F350 6.7 Diesel Crew
USAF - Military Training Instructor (TI) - 68-72
Wasps/Yellow Jackets cywylie General Repair Forum 6 02-23-2014 03:44 AM
Wasps in filling hole CarCollector Fresh Water Systems 6 03-05-2013 10:25 AM
A/C full of mud dobbers wasps! fred bartlet Furnaces, Heaters, Fireplaces & Air Conditioning 0 08-29-2012 03:36 PM
Why do wasps love furnace intakes ??? arcamedies Furnaces, Heaters, Fireplaces & Air Conditioning 6 06-28-2010 04:02 PM
Air Conditioner (wasps) ve3czn Furnaces, Heaters, Fireplaces & Air Conditioning 6 08-30-2007 05:29 AM
