Old 05-04-2016, 08:17 PM   #1
Becky B.'s Avatar
1964 17' Bambi II
Schererville , Indiana
Junky fresh water fill hose
What's the best hose for a new fresh water fill? I purchased one & it leaks like a sieve on both ends when tightened with hose clamps. My dear husband has replaced all the plumbing in our new to us 1988 Avion 32S & this is the place where it decided to leak.....Any suggestions of a really good quality hose?Click image for larger version
Name:	plumbing parts.jpg
his plethara of parts
Name:	water fill hose.jpg
the kind of water hose I ordered
Becky
1964 Bambi II
1988 Avion 32S
Becky B. is offline   Reply With Quote
Old 05-04-2016, 09:24 PM   #2
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
There are 2 that work for me. First is a hose that is a spiral and springy and retracts neatly. It is not specific for potable water. The one I use most is a flat hose which is designed for potable water. When not under pressure it is flat like a fire hose and is very compact. I would also consider one of those self retracting hoses. For me if a hose was designed for potable water is not as important as that is only what it is used for. Our drinking water is filtered at the sink or bottled water and the water in the tank or from the city water supply is not used for drinking or cooking.
Old 05-04-2016, 10:25 PM   #3
Caffeinated's Avatar
2015 27' Flying Cloud
Portland , Oregon
Becky, I'm no expert in this but it sounds like the hose you have is just not a good fit for your plumbing. I'd call a large Rv parts place and teell them what you are doing and maybe they might have the right bits for you. Good luck.
Mike
Caffeinated is offline   Reply With Quote
Can water heater fill from fresh water tank? phann Water Heaters, Filters & Pumps 14 02-04-2018 01:10 PM
fresh water tank fill hose leak Pat G Fresh Water Systems 2 09-03-2015 04:49 PM
Fresh water tank fill hose VAtom Fresh Water Systems 11 04-10-2015 03:20 PM
fresh water fill hose/adapter wmarsha Fresh Water Systems 7 08-12-2012 12:34 PM
new member & new junky tguns Member Introductions 6 06-28-2010 11:29 PM
