Old 10-23-2013, 04:57 PM   #15
Stefrobrts's Avatar
1968 17' Caravel
Battle Ground , Washington
Images: 50
Originally Posted by 28Argosy View Post
We have a 1976 Argosy 28. What types of things should we do for winterizing?
The tanks are empty.
I was thinking that we could put in a little space heater to run off electric once we hit the 20's.
I've done that almost every year, I think it helps keep it from getting musty inside too. I also like to have a Dry-Z-Air in there to soak up extra moisture. However, one year my electric heater failed, and leftover water in the pipes froze and broke a pipe, so be sure to blow out your pipes so there's no water left in the low spots. I usually put some RV antifreeze in the traps as well, just in case.
Stephanie
