Old 06-17-2012, 06:04 AM   #1
1989 29' Excella
Tyrone , Georgia
Isolating pump - Are pre-built braided lines too restrictive to flow?
Hey all. I am finishing up the pex transition and would like to know if the normal hoses at home depot are adequate for our purposes. Since the hose is roughly 1/3 - 1/4 the ID of the 1/2" pex I thought I'd ask.
mikeandnora is offline   Reply With Quote
Old 06-17-2012, 12:10 PM   #2
danlehosky's Avatar
2012 25' FB Flying Cloud
Gig Harbor , Washington
You'll keep pressure but lose lots of volume using these lines. They are made for single fixture point of use connections.
Dan
TAC
Hope is not a plan.
danlehosky is offline   Reply With Quote
Old 06-17-2012, 01:13 PM   #3
1974 Argosy 20
Kooskia , Idaho
If you are talking about the pre made up ones, with SS braided outside, they are not large enough. If you are talking about the vinyl tubing you can get at HD, with an interenal reinforcing braid, that is what you want. You will need a transition fitting to go from the vinyl to the pex of course.
Old 06-17-2012, 02:04 PM   #4
1989 29' Excella
Tyrone , Georgia
Ok. Thanks guys.
