Old 10-24-2015, 10:35 AM   #29
Long Island , New York
Although many of your thoughts, taken separately and literally, may be true (and rather obvious . . . ), you may have missed the gist of what I was getting at:
. . . that a 2 GPM pump (vs. a 4 GPM pump), together with concerted efforts to conserve water, will result in one's fresh water tank lasting longer (even "twice" as long).
A shift of awareness, that's all.
If you don't get it, that is fine . . .
OTRA15 is online now   Reply With Quote
Old 10-27-2015, 09:58 AM   #30
FYI my hand-held Delta shower head is rated at 2.5 GPM, and I assume the the outdoor shower is at least 1 GPM, the bath faucet 1 GPM, and the galley faucet about 2 GPM, for a combined total of 6.5 GPM. Reducing the pump size from 4 GPM to 2 GPM will thus force multiple concurrent users to make-do with a lower water flow, or make other accommodations, resulting in water conservation IMO.
Old 10-27-2015, 06:19 PM   #31
Bigventure's Avatar
2016 30' Classic
Hinckley , Ohio
Is there such thing as a silent water pump?
To quiet the water pump remove it at place an old mouse pad under it and remount it loosely. There is a screw on the front of the pumps for pressure regulation. It's on the pressure switch. If it cycles to often adjust it one way or the other to change the cycle.
If you could have a superpower, what would it be?
I chose America
Bigventure is online now   Reply With Quote
Old 01-18-2017, 08:26 PM   #32
2004 22' Safari
Albuquerque , New Mexico
What I really think you are suggesting is that people will use whatever they can get, so rather than conserving water, if they are able to get 4 gpm through the shower head, they will use it, if not, they will use what they can get.
Silver.Sanctuary is offline   Reply With Quote
Old 01-19-2017, 08:23 AM   #33
Vantair
Vantair's Avatar
2005 25' International CCD
Westlake Village , California
Intentional Restriction
In contrast yet maintaining optimum availailabe pressure thus quieter operation, installed new Shurflo Revolution 3GPM pump with "quiet hose kit" with a larger inner diameter, extra restricted flow washers to lav sink and Oxygenics 26481 shower head.
Resulting in less water waste in use, feel of a quality shower while making most of available GPM with less cycling demands.
Water saved is you own especially when boondocking.
Vantair is offline   Reply With Quote
Old 01-20-2017, 11:50 AM   #34
1Boyscout's Avatar
2015 28' International
Edmond , Oklahoma
Day dreamer,
which Serenity do you own, I own the 28', 2015.
where is your pump located?
mad hatter
Retired US
1Boyscout is offline   Reply With Quote
Is there such a thing as "hybrid" full-timing? mgriffrus Full-Timing 14 03-17-2013 03:09 PM
Didn't know there was such a thing as 14.5" rims 59toaster Wheels, Hubs & Bearings 1 05-04-2009 09:23 PM
Is there such thing as a trailer jack? Alluminatrix Jacks, Stabilizers, Lifting and Leveling 10 06-05-2006 09:12 PM
Is there such a camper? fabofabo Our Community 3 08-12-2004 11:04 PM
Is there such thing as a 1958 Bubble? 58BUBBLE Our Community 10 08-03-2004 04:31 PM
