Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures
Old 08-05-2015, 08:55 AM   #1
2015 30' FB FC Bunk
Ayer , Massachusetts
Is there such thing as a silent water pump?
My water pump is fine, but like yours, it sounds obnoxious.
Anyone know a good pump that is near silent?
Ted S. is offline   Reply With Quote
Old 08-05-2015, 09:35 AM   #2
1974 Argosy 20
Kooskia , Idaho
I think that most of the pumps are not bad in their noise level, but the mounting and the pipes connected to them are where the noise comes from. In addition, air in the pipes seems to be an issue in recent Airstreams.
You probably have a variable speed Sure Flow pump in you 2015 which is what I have in my 2014 FC 20'. Mine can be noisy as hell, or as quiet as a mouse with no way to tell why, although I believe now it has something to do with air in the lines. It most likely is not the mounting as that cannot vary from one day or trip to another.
In short, changing the pump may not solve the problem. I am still working on finding the issues with mine.
Old 08-05-2015, 10:15 AM   #3
Durango , Colorado
I have a 2015 Serenity and it came with a cheap FloJet pump that was noisy as hell. I too thought it was air in the lines because sometimes it seemed quiet. I worked and worked to quiet the pump and the hammering got worse. It got to the point where I know that there wasn't any air in the lines and the pump still hammered. It was just a a lousy pump.
I installed the ShurFlo 4048 bypass pump along with a little insulation and now it is very smooth and quiet. In addition it is a 4GPM pump so my flow to the shower and front sink is much better. There is still audible noise when the pump is on but it is more like a purr than a jack hammer.
RVDreamer is offline   Reply With Quote
Old 08-05-2015, 10:18 AM   #4
1974 Argosy 20
Kooskia , Idaho
Good to know RV dreamer.
Old 08-05-2015, 10:53 AM   #5
1974 Argosy 20
Kooskia , Idaho
BTW, my OEM pump is a a Shurflo 4900 0201 variable speed.
Old 08-05-2015, 11:01 AM   #6
2015 30' FB FC Bunk
Thanks RVDreamer
Do you thing there is any concern with over pressurization with a higher GPM pump? I believe the Airstream has a built in pressure regulator but the pump would be after it.
Old 08-05-2015, 12:05 PM   #7
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
Crud in your filter
Any pump will get noisier if the filter gets fouled. I just had to shock my white water tank because of an Algae problem. In addition I circulated the bleach solution through AND even replaced the white water hose (poured the bleach solution THRU the new hose and into the water fill to get that cleared out too!
Living in a coastal swamp... oh well. One thing I though about was that I installed an inline filter in the old hose, but put it in next to the spigot. The inline filter will remove any small amount of chlorine put in the city water - and then the rest of the 25 foot long hose lay on the ground in direct sunlight. The inside of the hose was green from some kind of algae as a result.
Old 08-05-2015, 12:19 PM   #8
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
What I use on my boat, silent with the occasional squeak.
http://www.amazon.com/MARINE-ACCESSO...oat+water+pump
MICHAEL
Old 08-05-2015, 12:56 PM   #9
Durango , Colorado
My in-line filter was spotless. I always filter my water before putting it in my trailer and we have very clean water in the mountains of Colorado. In my case the noise was just the pump. I think the FloJet that came with the 2015 trailer was just a cheap one-speed pump with no bypass. This caused it to hammer and cycle a lot, especially when using the toilet flush.
The new ShurFLow 4048 pump is a bypass pump and is adjustable so that when you use the water at a slower rate (say from the bathroom sink), the excess water is bypassed back to the inlet of the pump. This allows the pump to run smoother and not cycle on & off. I also think it just does a better job drawing water from the tank than the old pump which stops the hammering.
Old 08-05-2015, 02:49 PM   #10
mandolindave's Avatar
I wouldn't want a quiet pump
The sound is useful to me. I know when the pump comes on when it shouldn't, that I have a leak. I know when I am running out of fresh water, and I know when I ran out of fresh water.
The only drawback is if someone uses the toilet in the middle of the night. I get around that by turning the pump off when I go to sleep.
mandolindave is offline   Reply With Quote
Old 08-05-2015, 03:37 PM   #11
Moflash's Avatar
2007 28' International CCD
Springfield , Missouri
I put in a Shurflo Revolution and it made all the difference in the world.$110 and 15 mins.No more knocking obnoxious sound and more pressure.
Old 09-04-2015, 08:48 PM   #12
CraigFulton's Avatar
1962 22' Safari
Saint Petersburg , Florida
Images: 53
Send a message via ICQ to CraigFulton
Revert back to the old air pressure system :-). That's what I did! Like a super soaker squirt gun!
https://youtu.be/avRIpHurdCc
CraigFulton is offline   Reply With Quote
Old 10-16-2015, 12:15 AM   #13
Sag Harbor , New York
Did you go for the 4008 or 4048 pump perhaps?
SHURFLO® REVOLUTION™ Pump 12 VDC 3.0 GPM | REVOLUTION™ 4008 Pumps
SHURFLO® 4048 High Flow Pump | SHURFLO® 4048 High Flow Pump
Are you happy with the pressure and water flow?
I have a Flying Cloud 20' with smaller tanks, so minimizing flow is important.
Old 10-16-2015, 12:19 AM   #14
Originally Posted by idroba View Post
[snip]
You may be interested in the the new pump discussions in the FC20 thread.
Thanks for any ideas you have, including whether the Shurflo 4008/4048 pumps are quieter than your "Shurflo 4900 0201 variable speed," which the company claims to be the case as I read their specs.
Old 10-21-2015, 09:30 PM   #15
Moflash's Avatar
Very pleased with the results.Switched the shower head to a Oxygenetixs so we have more pressure with less water usage.
Old 10-21-2015, 09:54 PM   #16
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
I installed Shurflo Whisper King pumps in both trailers. Almost silent. I put a loop in the output hose and make sure that it doesn't touch anything so that there is nothing to bang against. If you want to get really silent, you can fashion a rubber mount. I didn't bother.
Past President, El Camino Real Unit WBCCI#6620
Street Rod Builder (see avatar)
Kite flier (check out links below)
https://www.youtube.com/watch?v=Bp3nuNtlZcA&t=331s
https://www.youtube.com/my_videos?feature=mhee
Old 10-22-2015, 02:32 AM   #17
Thanks Jim, it looks like that Whisper King pump has been discontinued. Do you happen to know its GPM rating? I see one old spec. online for 2.0 GPM.
Thanks also for the guidance on the output loop and rubber mount, both of which I am in the process of assessing on the 20-footer thread.
Peter
Old 10-22-2015, 02:33 AM   #18
Thanks I will check out that shower head for our Flying Cloud 20.
Old 10-22-2015, 05:50 AM   #19
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
It's one of the best additions I've made. It only uses .75 gallons/minute yet feels like much , much more.
2019 Ford Expedition Platinum
Old 10-22-2015, 08:06 AM   #20
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
No matter your pump choice, a flexible connection on both sides is the key to quieting things!
Rigid lines transmit lots of vibrations to surrounding surfaces!
Is there such a thing as "hybrid" full-timing? mgriffrus Full-Timing 14 03-17-2013 03:09 PM
Didn't know there was such a thing as 14.5" rims 59toaster Wheels, Hubs & Bearings 1 05-04-2009 09:23 PM
Is there such thing as a trailer jack? Alluminatrix Jacks, Stabilizers, Lifting and Leveling 10 06-05-2006 09:12 PM
Is there such a camper? fabofabo Our Community 3 08-12-2004 11:04 PM
Is there such thing as a 1958 Bubble? 58BUBBLE Our Community 10 08-03-2004 04:31 PM
