05-04-2016, 08:30 AM
1973 25' Tradewind
Beautiful
, Oregon
Installing a new toilet help
Hi Folks,
I suspect installing a toilet in a trailer is pretty easy but I am hoping I could get a step-by-step instructions. How is it different than a toilet in a house? Is it the rubber cone instead of a wax seal? If anyone had a picture of how they ran the final water connection to the toilet from the feed line I would love to see it. If no picture a description would be great. Does it bolt down the same way?
Anyway thanks in advance.
Tony
05-04-2016, 08:34 AM
Sneedville
, Tennessee
The only real difference is the seal. It's not a wax seal. Everything else is the same. Be sure to put a shutoff valve on the water supply.
05-04-2016, 08:48 AM
Full Time Adventurer
2007 27' International CCD FB
Nomadic
, USA
Family of 5 exploring the USA with a Ram Power Wagon & Airstream in tow.
OUR BLOG | INSTAGRAM
05-04-2016, 08:58 AM
Lost in America
2015 27' FB International
2004 19' International CCD
Santa Fe
, New Mexico
While all of the RV toilets install the same, they do come in different sizes, all though minute. You wanna be sure the lid and seat don't hit the back wall and not stay up.
This is the strangest life I've ever known - J. Morrison
2015 Airstream International Serenity 27FB
2017 Chevy Silverado 2500HD Duramax Diesel
05-04-2016, 09:08 AM
Spokane
Tony, the most important thing to consider when changing out the toilet is the dimensions of the new one. The distance from the center of the black tank opening to the back wall is critical. It is easy to remove your current toilet, usually just a couple of bolts and the water line.
There is no wax ring so nothing to replace provided your current one is not damaged. As far as the connections go, I used pex and a sharkbite like connector found at the local HD or Lowes.
I put in a Dometic 310 and it was the best upgrade I have ever made. The porcelain bowl is the way to go.
05-04-2016, 10:11 AM
1973 25' Tradewind
Beautiful
, Oregon
Thanks for the replies folks just what I needed.
BoldAdventure How to article great thank you
Tony
05-04-2016, 01:28 PM
2004 30' Classic Slideout
Fenton
, Missouri
As many of us age with our Airstreams, we sometimes experience some challenges in the physical aspects of our needs. At home I upgraded one of our toilets to ADA height to better accommodate getting up and down from the toilet.
In the Airstream we were happy with the existing toilet but it's lowness did provide some issues. Rather than replace the entire unit, we found that Thetford makes a riser that gives us 2 1/2 inches of additional height. It comes with all gaskets and bolts and the only modification I had to make was to provide some extension to the water line that feeds the toilet.
One thing to be aware of in replacing a toilet or putting in a riser is the fact that clearances might be affected. In the case of my Classic, the door of the cabinet next to the toilet just cleared the old toilet with the seat and lid down. Not so anymore which means the seat and lid must now be up to open the storage cabinet door. We don't access that storage compartment much so it wasn't a big issue.
Jack
Jack Canavera
STL Mo.
AIR #56 S/OS#15
05-04-2016, 03:08 PM
2005 30' Classic
Box Elder
, SD
We replaced our Thetford Bravura (OEM) with a Dometic 320 high rise with sprayer about 9 months ago. As the previous posts indicate, BE SURE of your dimensions/clearances! Our install took me 30 minutes AFTER I finally found the correct 'shark bite' connector for our pvc pipe coming out of the wall connecting to the SS braided connector to the toilet.
This 320 is a DREAM! We never realized how low the Bravura was.
Good luck on your install
04-25-2017, 08:50 PM
1978 25' Tradewind
Carlsbad
Which model?
Hello, I have a '78 Tradewind and I'm looking to replace the toilet with a Dometic 310. Which model did you use? I'd like to make sure it will fit.
Thanks! Erik
Erik
'78 Tradewind International
'72 Chevrolet Cheyenne K20 Super
