Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures
Old 09-10-2018, 10:30 AM   #1
65will
65will's Avatar
1969 25' Tradewind
Greenwich , New York
installing a gray tank in my 69 Trade Wind
Hello, I want to use the existing drain pipes for my gray water. Where it comes through the floor to my dump hose fitting I want to cut and turn it 90 degrees and plumb to a pair of gray tanks over the axels. Also remove my black dump valve 90 that to a new combined valve just behind the rear axel. Has anyone done this?
65will is offline   Reply With Quote
Water tank '79 Trade Wind douggant Fresh Water Systems 0 06-20-2018 03:41 PM
Dump valve clearance on a retrofit 1965 Trade Wind Gray & Black Tanks Rocker66 Waste Systems, Tanks & Totes 6 04-23-2015 10:19 PM
1972 Trade Wind - Storage Tank Questions camdwilson 1970-79 Tradewind 10 07-09-2009 06:54 PM
Add Grey Water Tank to 1972 Trade Wind? AronS Waste Systems, Tanks & Totes 8 07-25-2007 07:43 AM
Replacing Black Tank 1966 Trade Wind Pat66TW Waste Systems, Tanks & Totes 2 06-30-2003 08:42 PM
