Old 09-10-2016, 09:57 AM   #1
dsrtgrls's Avatar
2010 19' Flying Cloud
Clarkdale , Arizona
install of shurflo pressure reducing city water entry
i again have to replace this inlet on my 2010, 19' fc. it is leaking into the inside of trailer when hooked to city water supply. i use a water pressure reducer when hooked to city water and a angle connection on the inlet outside the trailer to reduce stress from the connected hose. i have reviewed shurflo's install instructions which say not to install this unit directly to rigid pipe, but to connect to flexible hose then to the pipe. shurflo says that if not connected to flexible hose the stresses from connecting directly to rigid pipe can cause it to fail. airstream has it connected directly to the white rigid plastic pipe.
1) does anyone have this inlet connected the way shurflow directs or are you connected directly to the rigid plastic pipe?
i would like this piece to last longer than it has been and am really wondering if the way it is connected to the interior rigid pipe needs to be changed. here is a picture of my current connection. any input would be appreciated. it is leaking just like the original did from the bottom screw area. wet insulation not good
"Open paddock 9!"
dsrtgrls is offline   Reply With Quote
Old 09-10-2016, 10:00 AM   #2
dsrtgrls's Avatar
Clarkdale , Arizona
here is pic i hope
http://www.airforums.com/forums/atta...1&d=1473523152
"Open paddock 9!"
Old 09-10-2016, 10:01 AM   #3
dsrtgrls's Avatar
Clarkdale , Arizona
sorry it is sideways. will get this right some day.
"Open paddock 9!"
Old 09-10-2016, 10:08 AM   #4
dsrtgrls's Avatar
Clarkdale , Arizona
http://www.airforums.com/forums/atta...1&d=1473523696
this is shurflo instructions.
"Open paddock 9!"
Old 09-10-2016, 11:18 AM   #5
Home of Vortex tuning
CDONA's Avatar
2013 27' FB Eddie Bauer
Spearfish , South Dakota
I had to replace mine, I tightened the screws and stopped the leak for a month or two, I did take it apart to reseal it, after I installed the new one, and kept it for a spare. I started getting the leak again and swapped out the new for the resealed. I couldn't get the new one to leak to see the wet spot.
I think cold water, close to freezing, loosened the connection to the interior line, for I reinstalled the new one with tightened connection and it quit leaking. I had a cold water issue on another rig that caused a loose connection/leak.
I do run a 90* elbow on exterior connection but don't double up on the restrictors
"Chip Tank" is in Hope Az.
CDONA is offline   Reply With Quote
Old 09-10-2016, 11:26 AM   #6
Springville , Alabama
I too had to replace mine last year on my 2005 25' safari, and ran into the same issue with the flex vs. rigid. I ended up just connecting back to the existing rigid pipe due to ease of replacement, even though the instructions said to use flex. I guess I will find out with time if this was wrong decision. By the way, mine had cracked in the cold weather last winter. so was not a really a pipe connection issue. That corner of my trailer is the low spot where I park, and the water must have accumulated at the inlet, and I did not push air through my lines to dewater them last year. If your leak is not related to freezing, but road vibration, then flex hose would solve that I would think.
driftwood1 is offline   Reply With Quote
Old 09-10-2016, 11:41 AM   #7
dsrtgrls's Avatar
Clarkdale , Arizona
we began our camping season in march of this year going on about 3 trips. this was our 4th outing at the end of august that the leak showed up. i believe that the original inlet might have been from freeze but this one i do not think so as it has not leaked until now. it has been in about 2 years so it has seen 2 winters already. just wondering what connections others had in view of the shurflo directions do determine best prractice for a better outcome. thanks for any and all input. it is hard for me to know how to improve on this.
"Open paddock 9!"
Old 09-10-2016, 12:17 PM   #8
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Before replacing it determine exactly what is leaking. Could it be one of the connections is loose?
I suggest:
1. add clamps to the short white pipe (could there be a drip here) and make sure the pipe is adequately supported so that it is not hanging it's weight on the inlet. I think pex clamps should have been installed at the factory.
or
2. replace the black threaded adapter, the ell, the white pipe, and the white connector with a flexible hose with proper threaded ends. (this will eliminate any weight and vibration of the rigid pipe being connected)
Alan
Old 09-10-2016, 12:34 PM   #9
dsrtgrls's Avatar
Clarkdale , Arizona
all connections seem dry. the drips form at the bottom right hand corner of the inlet by the screw there. all is tight but i think i am leaning toward the flexible hose install for the replacement to rule out weight and vibration gremlins thanks
"Open paddock 9!"
Old 09-10-2016, 01:09 PM   #10
1979 23' Safari
Wayland , New York
Pretty common for these to leak where the two halves come together. Especially when piped this way. You can try tightening the screws, sometimes it works for a little while.
You're right on the instructions! Water heaters say the same thing. Unfortunately most RV mfgs have been hard piping them to PEX. Shur flow makes a fitting to replace the one there with one that goes to a elbow threaded connection. You can then thread on some flexible hose with some barb fittings from the hardware store, fittings on the other end to go back to PEX. I bought a inexpensive 1/2" 10' white camco potable water hose to cut to make the connection.
Old 09-10-2016, 02:52 PM   #11
2004 25' Safari
1968 17' Caravel
Fountain Valley , California
My 1968 Airstream did not have a convenient outside city water hookup, so about a year ago I installed the Sureflo pressure reducing water entry. I did hook it up with flexible hose per the instructions.
WindyJim is offline   Reply With Quote
Water Pressure: Shore pressure high, All pressure in trailer low.... bhooves Sinks, Showers & Toilets 9 10-16-2016 03:22 PM
city water inlet pressure reducing unit - fixing/buying a replacement monkeydance Fresh Water Systems 3 02-29-2016 10:50 AM
Shurflo city water regulator question dlb435 Fresh Water Systems 9 01-18-2014 04:40 PM
Replaced city water SHURflo pressure relief valve fitting silverback Fresh Water Systems 3 06-01-2010 01:32 PM
shurflo city water inlet urbanfood Fresh Water Systems 3 08-19-2007 03:25 PM
