Old 07-23-2015, 01:23 PM   #1
2007 25' Safari SS SE
Naperville , Illinois
Install 9601 Moen filter
Help! We bought a new 9601 Moen Filter and can't get it to seat in the fitting in our 2007 Safari. Is there a trick to it?
Nicknbarb is offline   Reply With Quote
Old 07-23-2015, 01:52 PM   #2
Wise Elder
Jammer's Avatar
2010 30' Classic
You have to hold it straight and level, push in fairly firmly, and twist 120 degrees. There's no other trick. You can reach with one hand behind the filter head to hold it, if you have long arms and are fairly flexible, which will help.
How to replace Moen 9601 ChoiceFlo Filter under sink bonginator Water Heaters, Filters & Pumps 5 11-08-2014 10:08 AM
No more Moen filter in my Safari Brow324 Sinks, Showers & Toilets 10 04-28-2012 12:19 PM
how to remove moen undersink water filter on 2010 bambi dsrtgrls Water Heaters, Filters & Pumps 5 12-06-2009 07:38 AM
2006 Classic Moen Faucet Filter Pappy Water Heaters, Filters & Pumps 18 10-02-2006 10:54 AM
Moen 601 water filter jcanavera Water Heaters, Filters & Pumps 3 04-04-2006 09:29 PM
