Old 11-07-2016, 12:59 AM   #1
2016 FC27FB - F350 2017
2016 27' Flying Cloud
Fort Lauderdale , Florida
Send a message via Skype™ to Vitaver
Inline water filter, why not a whole house canister?
Short of reverse osmosis, a canister with a filter to keep sediments and other stuff out of your water though activate carbon, etc. Why is that not the natural choice of water treatment between the spigot and our fresh water/city water inlet?
Something like https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
I will replace my one inline cartridge (https://www.amazon.com/Camco-40045-T...e+water+filter) Camco, the 'standard issue' one, by a whole house one. Any reason why not?
Thank you for any input.
Vitaver is offline   Reply With Quote
Old 11-07-2016, 03:10 AM   #2
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
Smaller means easier to pack. Small and dripping beats big and dripping, so to speak.
I realize that the sky is the limit for water treatment. But for GP use, the little hose filter is fine.
The larger filter may not add any benefit for our use. Having had one I switched back to the smaller.
1990 35' Silver Streak
2004 555 Cummins
Old 11-08-2016, 12:38 AM   #3
We drink the water out of the sink faucet rather than carry bottles or a separate pitcher. Currently have one inline filter on the hose and then the second under the sin. My thoughts are just to make the water 'better' with a full house larger canister type filter that includes particulae, activated carbon, etc. It restricts the flow, but lower pressure can be a good thing. The cartridge is not much larger than a good bottle of champagne... and since we don't carry any champagne we accept the trade off. Just curious why others don't do the same (I am not talking about the champagne!)
Old 11-08-2016, 12:53 AM   #4
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
I've been using whole house type filters on each of my trailers since the mid 1990's.
The filter cartridge needs to be changed at least once a year. When I change the filter I sanitize the interior of the canister with bleach each time, before the new filter goes back in.
I use the activated charcoal filters.
ps:
DW still uses bottled water, but I mostly use water from the tap for drinking. We both consume faucet water for coffee, tea, and cooking.
Alan
Old 11-08-2016, 03:50 AM   #5
Cruiser6483's Avatar
1954 25' Cruiser
Bern - Thun , Berner Oberland
Images: 31
I do not know what I take for a system. For drinking water, I mounted a small hand pump, including a canister which you can fill up everywhere.
Greetings from Switzerland - Werner
Cruiser6483 is offline   Reply With Quote
Old 11-08-2016, 04:33 AM   #6
Long Island , New York
We use the inline Camco filter to save weight, simplify winterization, reduce things in trailer which can break/leak, and filter water going into water tank.
This last point is probably the most important. Advise using inline filter to fill tank, especially at CGs with impure well water which often has grit and sediment, which can mess up the back-flow check valve at the pump.
Inline filter also supports use of potable water jugs to fill fresh water tank from remote spigots while Boondocking.
Lots of good reasons IMO.
Keep it simple, Stu . . .
PS we also use inline water pressure regulator. Redundancy good. Belt and suspenders, etc..
Old 11-08-2016, 06:20 AM   #7
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
My system,
https://www.rvwaterfilterstore.com/i...ter%20Dual.jpg
From,
https://www.rvwaterfilterstore.com/index.htm
MICHAEL
Old 11-08-2016, 06:51 AM   #8
Caffeinated's Avatar
2015 27' Flying Cloud
Portland , Oregon
Yep, me too.
Mike
Caffeinated is offline   Reply With Quote
Old 11-08-2016, 08:01 AM   #9
daboose's Avatar
2014 25' FB Flying Cloud
Matthews , North Carolina
Images: 11
Ditto
+1
daboose is offline   Reply With Quote
Old 11-08-2016, 08:02 AM   #10
RLS
RLS's Avatar
2004 25' Classic
Prescott , Arizona
WE have this: https://www.amazon.com/Hydro-Life-52...DF1Q6JJD4S675P
I have 2 brackets, one is mounted in the closet for storage and the other is mounted on the access door for the fresh water. The cartridge holder slides into these brackets.
Julia & Bob
W/ Deedee & Boo
AIR #30685
RLS is offline   Reply With Quote
Old 11-08-2016, 08:16 AM   #11
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
They most likely filter the same stuff out, but a whole house is designed for the much greater flow of a whole house(multiple bathrooms, kitchen, appliances). I think it's overkill.
Carry the smaller inline and you'll have room for that grey hose.
2012 Dodge Durango Hemi/AWD
Old 11-08-2016, 12:43 PM   #12
Glenn T's Avatar
2011 20' Flying Cloud
Lemont , Illinois
I've used the small Camco filter, but prefer the whole-house filter because it doesn't restrict water flow nearly as much. This makes filling the water tank MUCH faster. Also, it provides much better water flow if the campground system isn't very high pressure, and especially in the event you have to use extension hoses to reach the camper.
Glenn T is offline   Reply With Quote
Old 11-08-2016, 01:47 PM   #13
Seagars's Avatar
2017 16' Sport
Suwanee , GA
Why not just have a countertop brita for drinking?
Seagars is offline   Reply With Quote
Old 11-08-2016, 02:24 PM   #14
AWCHIEF's Avatar
Images: 33
No reason not to use one, if that is what you want to do.
MICHAEL
Inline filter under kitchen sink SeaLevel Plumbing - Systems & Fixtures 11 09-24-2016 06:34 PM
Best inline water filter. schoochie11 Water Heaters, Filters & Pumps 1 12-06-2015 11:51 AM
345 inline fuel filter info. 345bill Classic Motorhomes 2 09-18-2009 07:44 PM
Whole-house surge suppressor? Foureagles Electrical - Systems, Generators, Batteries & Solar 9 03-03-2008 04:29 PM
Chrome Canister "U-FIL" Water Filter jaco Water Heaters, Filters & Pumps 1 05-06-2004 01:53 PM
