Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures
Old 09-28-2014, 06:50 PM   #1
2008 25' Safari
Littleton , Colorado
Increasing Black Water Tank Size
We are considering buying a 2008 Safari 25 that has an 18 gallon black water tank. Is it possible to install a larger capacity tank?
Mellinkat is offline   Reply With Quote
Old 09-28-2014, 07:24 PM   #2
Usually not, without extensive modifications to the frame.
Your present tanks have filled the room available withinn certain frame cross members.
You could increase the size of it vertially, but then you would have to design and installa steel frame to support it, that would lower the underbelly. That would also make you empty that tank before any travel, because if it was near full, you would have altered the toungue weight, which would alter the trailer handling when it's towed, plus adding additional weight to the rear, which the original design will not handle when hitting bumps.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 09-28-2014, 07:36 PM   #3
Ag&Au's Avatar
Port Orchard , Washington
I don't know, but I seriously doubt that it would be practical. I think you will find that if you are careful when flushing it will take lot longer to fill that tank that you think. It is the gray water tank that most often fills first.
Here is what most people do to extend capacity of grey and black water tanks.
http://www.amazon.com/s/?ie=UTF8&key...l_3m287riktj_b
Ken
Replacing black water tank with grey water tank cheetah1 Sinks, Showers & Toilets 25 10-02-2014 05:26 AM
Black Tank, Grey Tank, New Tank, Old Tank Bunkroom Waste Systems, Tanks & Totes 3 07-22-2014 08:35 PM
Increasing number of "Latest Discussions" displayed via Portal Alphonse Forum Admin, News and Member Account Info 8 02-16-2014 12:39 PM
Increasing fuel mileage ITowSilver Tow Vehicles 11 09-13-2006 09:31 PM
Size of black water tank glyoungca Waste Systems, Tanks & Totes 3 06-10-2002 04:17 PM
