Old 10-22-2006, 03:58 PM   #1
1975 29' Ambassador
Monkton , Maryland
in the process of getting water system working
I bought a 175 Ambassador a few weeks ago and I am now in the process of getting everything to work. Put a convertor in the electricla part appears to be working now, so I have mode on to the water system.
The control panel shows three gauges 'water tank' and 'auxiliary holding tank' and 'main holding tank'.
After I put some water in the water tank and throwing the water pump switch, the pumpt starts (noisy) and it starts to pump water to the rear through a clear hose. It appears it is going to a tank in the rear.
Is there a valve that I need to close so that the pumpt stops running?
Robert
wavemaster is offline   Reply With Quote
Old 10-22-2006, 04:36 PM   #2
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
When you turn the pump on it tries to fill the all water lines and water heater. Make sure the water heater has the drain plug installed and the pressure relief valve is closed. Much of the noise you hear is the pump trying to compress the air in the lines. When I fill my lines I leave the bathroom sink faucets open untill water flows out. Then I go around and let the air out of every where else( shower, toilet and kitchen sink). The pump will then shut off. This takes a few minutes.
Richard
Old 11-14-2006, 03:19 AM   #3
1975 29' Ambassador
Monkton , Maryland
drain plug on waterheater - where is it?
I replaced most of the copper piping, it was split in the back as well as messed with near the pump.
The pump still doesn't stop running.
I don't know if the PO opened up the drain on the waterheater. Where is it?
29' Ambassador w Rear Bath.
Robert
Old 11-14-2006, 05:46 AM   #4
enduroryda's Avatar
1994 21' Sovereign
Down on the corner... , CT
Here is a pic of the drain on your water heater. The plug is not there and you can see the water coming out on the bottom left. I think you would know if it were open.
I would be sure the holding tank is full and be patient...it takes a while to fill the waterheater and the rest of the lines. Do what AZ said to do and open all the lines one at a time to clear the lines of air.
Ann & Eric
WBCCI 6274
TAC CT-4
NEU
enduroryda is offline   Reply With Quote
Old 11-14-2006, 09:14 AM   #5
1975 29' Ambassador
Monkton , Maryland
Leaky waterheater!
Cap was on the drain, unfortunately.
Turned out to be a lot of water leaking from the waterheater.
Can anyone provide me with guidance on how to remove it? Is it worth it to repair, or should I just replace it?
thanks in advance,
Robert
Old 11-16-2006, 03:21 PM   #6
2002 25' Safari
Dewey , Arizona
Images: 62
Robert ~ If the tank itself is leaking, replace it. It could also leak at the relief valve or at the water in line or water out line. If you are going to replace the water heater it comes out from the outside of the trailer. Disconect the water lines, the propaneline and the wires. Remove the attaching hardware to the skin and pull it out. It is a tight fit and will not come out easily.
Richard
Water Hammer smily Water Heaters, Filters & Pumps 10 02-08-2003 04:18 PM
travelling w/out water system maznblu Fresh Water Systems 6 09-09-2002 12:03 PM
city water inlet valve failure? JohnGalt48 Fresh Water Systems 2 08-01-2002 04:43 PM
Size of black water tank glyoungca Waste Systems, Tanks & Totes 3 06-10-2002 04:17 PM
Water lines in '73 Overlander Bryan Fresh Water Systems 8 06-05-2002 11:42 PM
