Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures
Old 07-31-2013, 11:08 AM   #1
bendstream's Avatar
2003 22' International CCD
bend , Oregon
In the closet, should this valve be open or closed?
And what is it for? Thanks
Name:	AS Valve?.JPG
Knowledge without experience is just information
bendstream is offline   Reply With Quote
Old 07-31-2013, 11:16 AM   #2
DKB_SATX's Avatar
Alamo Heights , Texas
With the middle valve open and the other two closed, you bypass the water heater for winterizing (so you don't have to fill the water heater with RV antifreeze.)
With the middle valve closed and the other two open, water flows through the water heater for normal use.
— David
Old 07-31-2013, 01:40 PM   #3
bendstream's Avatar
bend , Oregon
I printed this out and posted it in there.
