Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures
Old 05-06-2006, 10:36 AM   #1
flyfshr's Avatar
Profile:  1959 24' Tradewind
Phoenix , Arizona
Images: 40
Airstream Registry
In Need of a Part
The toilet in my '59 Trade Wind is missing the rubber cap to the vent on the riser. This particular toilet is from a '62 Safari and I think the factory used these toilets on a number of model trailers. Anyone have a spare one of these or know where I can get one?
FF
WBCCI/VAC #2699
Air #10
AZ-1
I'm haunted by aluminum.
http://www.airztream.com
http://59tradewind.blogspot.com
flyfshr is online now   Reply With Quote
Old 05-06-2006, 10:59 AM   #2
Profile:  , Minnesota
Images: 59
Airstream Registry
Brad,
If it's just a cap, you can buy them anywhere, but I suspect your are looking for an AAV (air admittance valve). http://www.toolbase.org/techinv/tech...chnologyID=140
Usually these are used in sinks to prevent sucking out the traps. Not sure how it would work on a RV style toilet without a trap. ?? What you need is a different style of air expeller valve that lets sewer gas out as you flush.
On my '59 Tradewind, the vent continued up through the wall to an outside roof vent.
Old 05-06-2006, 11:09 AM   #3
flyfshr's Avatar
Phoenix , Arizona
Images: 40
Airstream Registry
Hey Don ~
Just need the cap. The toilet is not hooked up directly to water. We use a spayer only so the cap is just for visual purposes. I've seen one up close on Shari's GT and it has the SaniWare logo.
FF
WBCCI/VAC #2699
Air #10
AZ-1
Old 05-06-2006, 11:23 AM   #4
lewster's Avatar
Profile:  2006 19' International CCD
Marco Island, FL , Hood River, OR
Originally Posted by markdoane
Brad,
That must be the pre-curser to the vacuum breakers that are found on every 'modern' RV now. You need one for every P-trap and toilet for the very reasons mentioned above. Keeps the stinkies in the tanks!!
Lew Farber -Certified Master RV Tech (currently on Forums posting sabbatical, but lurking in the background )
WBCCI #1456 and about to resign!/VAC (assoc) #1456/ AIR # 10325
TAC# OR-1
CHARTER MEMBER: FOUR CORNERS UNIT
HELP PART NEEDED! Aluminum Termination Cap... InsideOut Waste Systems, Tanks & Totes 46 03-20-2006 06:08 AM
Skylight part question ColtSAA45 Roof Vents, Skylights & Fans 3 04-22-2004 08:05 PM
Stupid human tricks, part 2 74Argosy24MH Off Topic Forum 9 12-22-2002 01:14 PM
What is the MOST you have paid for an AIR STREAM part overlander Our Community 64 11-19-2002 05:15 PM
Skinner air valve part # benbailey Airstream Motorhome Forums 1 10-19-2002 09:03 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
