Old 07-12-2014, 12:17 PM   #1
Growing old but not up
1972 29' Ambassador
St. Louis , Missouri
I'm no plumber but...
IF this doesn't leak does anyone see something I need to correct. The clear tubing connection was stuffed with 3/4 braided and then clamped coming off the right side of the tank. Is there a fitting to accomplish this that I didn't see at the big box store?
Name:	2015-01-03 00.42.18.jpg
ID:	216200   Click image for larger version
Name:	2014-12-30 06.56.09.jpg
riskstl is offline   Reply With Quote
Old 07-12-2014, 12:47 PM   #2
Zil
egg harbor city , South Jersey
what is the white flex hose?
Looks like the fitting on the clear is too small. Replace the clear?
Zil is offline   Reply With Quote
Old 07-12-2014, 02:16 PM   #3
1972 27' Overlander
Denver , North Carolina
Wow, this is cool I am working on my 72 Overlander. I'm going to run the drain lines out the back instead of through the kitchen floor. Get a small air compressor and blow some air through it. That way you'll know whether it will leak.
Lucky Dave, Denver NC
mccrosti is offline   Reply With Quote
Old 07-12-2014, 02:17 PM   #4
1972 27' Overlander
The white flex hose is coming from the fresh water tank.
Plumber's putty vs. silicone for shower pan rippie Plumbing - Systems & Fixtures 15 03-04-2014 09:32 PM
Plumber's putty or glue? cathy624 Sinks, Showers & Toilets 13 11-29-2010 05:49 PM
In search of a UK bespoke interior fitter/plumber Rachelreynol General Interior Topics 5 07-10-2008 02:51 AM
Not an Airstream but interesting dienst1 Airstream Motorhome Forums 11 09-15-2002 11:16 PM
Too hot but had a good time suekozin On The Road... 11 07-20-2002 02:45 AM
