Old 04-05-2015, 09:27 PM   #1
2010 25' FB Flying Cloud
Snoqualmie , Washington
ideas on slow city water fill - Newbie asking
Filling my Airstream from my outside house fawcet today - for the first time - before taking my 2010 25FB out next week for the 1st time. I have had the water on for over 2 hours - and the indicator in the kitchen only shows 1/4 to 3/8s full. No kink on Hose. Not flowing out anywhere.
of course the indicator could be broken i suppose (but how likely is that).
Any ideas (also - hose is brand new RV qualified hose). No pressure regulator connected.
Anders79 is offline   Reply With Quote
Old 04-06-2015, 05:47 AM   #2
Gainesville , Florida
Do you have the hose screwed into the shore water port? To fill the tank you must push the hose into the external water fill hole. Unless they have changed things there is no way to attach the hose to this hole. Usually this fill is behind a locked door. Someone please chime in if I am wrong. Jim
Old 04-06-2015, 06:44 AM   #3
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
I agree with Jim, I suspect you have the hose connected to the "city water" fixture and not to the fresh water tank fill. The fresh water tank fill is behind a small locked plastic door. There is no thread on the fresh water fill, you must basically stand there and hold the hose while you fill the fresh water tank or shove it in sufficiently so that it stays put.
The "city water" and "fresh water tank" fill inlets are not connected in any way. They are kept separate to provide you with the flexibility to connect to a city water supply without introducing any unwanted water into your fresh water tank.
Bob Martel
WBCCI# 5766
Old 04-06-2015, 07:26 AM   #4
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
I agree that's all it could be. You must have the hose hooked to the city water inlet. In the photo below, the fresh water tank is filled from the inlet behind the door.
Brian
SuEllyn & Brian McCabe
Old 04-06-2015, 11:42 AM   #5
B00merang's Avatar
2010 20' Flying Cloud
Hailey , Idaho
and maybe the drain valve underneath the AS has been left open...although that stream should be a lot less than your typical city water stream. The guys above are probably correct...
B00merang is offline   Reply With Quote
Old 04-06-2015, 12:01 PM   #6
Hmm, confused. what does the city water line provide then -- just water direct to the toilet, shower and sink and hot water heater; and that the water tank is completely separate.
Old 04-06-2015, 12:05 PM   #7
moosetags's Avatar
The city water inlet provides unlimited water to the whole trailer, but it does not fill the freash water tank. The fresh water tank provides water to the whole trailer also, but only when the water pump is turned on.
The inlet behind the little is the only way to add water to the fresh water tank, and it is separate.
Brian
Old 04-06-2015, 12:37 PM   #8
OK Thanks a Ton! Wondering -- if going camping where there is city water -- do most people leave their water tank empty (and only fill - when going somewhere where there is no city water?) P.S. We take our first trip tomorrow (very excited).
Old 04-06-2015, 12:42 PM   #9
Durango , Colorado
Think of it this way.
If you are at a campsite with water; Screw the hose into the city water inlet and it will provide water pressure and water to the whole trailer. However your water storage tank will remain empty.
If you fill your water storage tank with water before going on a trip then you can provide water to the entire RV by turning on the pump to provide water pressure. You do not have to be connected to an outside source.
Don't use the City Water connection for filling as it won't fill. Use the water inlet with no threaded connection to fill your water storage tank.
Also don't use your pump when connected to City Water, use your pump when you want to access the water in your water storage tank.
RVDreamer is offline   Reply With Quote
Old 04-06-2015, 03:19 PM   #10
Chelsea , Michigan
Images: 12
Most people travel with a very small amount of water (or even no water) in their fresh water tank if they are going to campgrounds with "city water." Otherwise you end up dragging around a lot of unnecessary weight. If you are going to a campground where there will not be any fresh water at your camp site and none in the campground at some remote potable water source, then you would fill your tank at home.
Given that this is your first experience camping, I would suspect that you selected a campground with full hook ups (water, sewer & electricity) so you can learn how to camp without being concerned about these items.
Enjoy!
Bob Martel
WBCCI# 5766
Old 04-06-2015, 03:38 PM   #11
Landrum's Avatar
2014 25' FB International
Little Rock , Arkansas
We have yet to camp without a water hookup, but I usually keep a few gallons of water in the tank for pit stops. It's very nice being able to stop anytime to use the restroom (especially since a certain member of our family usually has to stop before we even get out of town).
Landrum is offline   Reply With Quote
Old 04-06-2015, 03:39 PM   #12
1986 31' Sovereign
Miami , Florida
On the other hand, I always travel with a full water tank. Nice to be able to flush the toilet enroute to the next stop and, in my case, that 320# of low slung weight lowers the center of gravity of my rig which, and this is entirely anecdotal, I believe enhances stability.
Mike
new (usually dirty) Nissan Titan XD (hardly paid for)
Old (enhanced with "male pattern baldness") Sovereign
Young, lovely bride
Goofy dog, dismissive cat
Old 04-06-2015, 03:45 PM   #13
Traveling with water in the tank allows you to wash hands, flush, even take a shower when enroute. Jim
Old 04-06-2015, 04:03 PM   #14
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
We usually travel with water in our fresh water tank because we are not always sure where we will land. Our fresh water tank is pretty small, so the addtional weight is not much, and it also lowers the center of gravity on our rig.
On your shakedown cruise, if you have full hookups, take the opportunity to experiment with ALL your systems, including using the fresh water tank and operating off batteries. Try your AC and furnace as well.
And if you run into trouble or have questions, fellow campers or camp hosts are usually helpful...
And HAVE FUN!
TB & Greg and Abbey Schnauzer
#3954
drip at city water fill pvmsteve Land Yacht/Legacy Motorhomes 10 06-10-2013 04:59 AM
water dripping from city water hose attachment location when NOT hooked up to city wa Wilmington Plumbing - Systems & Fixtures 1 03-19-2012 09:25 PM
Need advice on removing City Water Fill on 1994 Limit Don McKelvay Fresh Water Systems 2 11-01-2011 10:47 PM
Proper City Water Fill, 30A inlet, etc. Placement? worldinchaos General Repair Forum 5 08-16-2011 02:39 PM
Fresh Water fill from City Inlet question Distantdrummer Fresh Water Systems 7 07-15-2010 05:38 PM
