Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures
Old 04-06-2008, 04:43 PM   #1
OregonArgy's Avatar
Profile:  1978 Argosy Minuet 6.0 Metre
Gresham , Oregon
How to transition to PEX?
I just noticed a leak in a very inconvenient place. I had removed a shelf in the lav closet to get to it. The offending T is the first picture below. I'm thinking of using PEX as a replacement. The second picture is a transition to vinyl tube around the water pump. This is a material I'd rather NOT use, even though it is a material I know how to use. I'd be comfortable with it, but I don't think it is right to use. The third picture is a better photo of the material I currently have in my '78 Argosy.
First, what is this current material called? Second, what sort of transition fitting would I use from the old stuff to PEX after I cut out the 3 branches of this offending tee?
Thanks!
ID:	57703  Click image for larger version
So...you bought a vintage trailer, did you, honey? Good deal, was it? Oh, just a couple of repairs, huh?
Drat, now our little Argy is starting to grow on me. I guess you were...were...were...right, honey.
OregonArgy is offline   Reply With Quote
Old 04-06-2008, 04:51 PM   #2
Gen Disarray's Avatar
Profile:  1968 24' Tradewind
Lawton , Oklahoma
It is my understandng that the compression fittings (I think thats the term) for PEX that link any material. Expect to pay $3-5 a fitting.
Rodney
The trouble ain't that there is too many fools, but that the lightning ain't distributed right.- Mark Twain
Visit my photography page at:http://www.pbase.com/professor_chaos
or my new travel site
Synapticstorms (under construction)
Gen Disarray is offline   Reply With Quote
Old 04-06-2008, 04:57 PM   #3
Fyrzowt's Avatar
Profile:  2000 25' Safari
Templeton , California
Images: 8
Check this thread for ideas. I have used Sharkbite, it works great and is re-usable. Transitions from copper to pex. The fittings are made of brass and a bit pricey.
I know Lewster uses another product that is cheaper that he likes.
Good luck.
Dave
Sharkbite
AIR #15800
"Wimpy" 1/2 ton 2002 GMC Sierra 4X4 Z-71 Gasser
2000 Safari SS 25'
Fyrzowt is offline   Reply With Quote
Old 04-06-2008, 05:31 PM   #4
OregonArgy's Avatar
Gresham , Oregon
Good ideas
I just went to the Sharkbite site and the SeaTech site. I think I'll be running by Lowe's and Home Depot next week. I'll grab a straight-line connector of each style and see if they attach to my product.
I'm still wondering what mine is. It is gray plastic piping, if the color isn't clear in the photos. Do you think it could be called CPVC?
Old 04-06-2008, 08:07 PM   #5
azflycaster's Avatar
Profile:  1975 25' Tradewind
Phoenix , Arizona
Images: 36
You may have Polybutylene.
My home had it before I bought it and it was re plumbed with CPVC which looks like regular PVC. If it is Polybutylene, you will want to remove it all. I don't think you can still get any money from the law suit at this late date, but you might check.
Richard
Charter Member Four Corners Unit
azflycaster is online now   Reply With Quote
Old 04-12-2008, 03:40 PM   #6
OregonArgy's Avatar
Gresham , Oregon
All fixed!!
I just finished the repair to this leak. I went down to Lowe's and used SeaTech push-in fittings. They are a bit expensive, but worth twice the cost in their ease of use. I can't believe how quickly the repair happened.
The only problem, my mini pipe cutter wheel ended up dropped down between my gray water and black water tanks. Uh-oh. Oh well, I guess I'll get it whenever I end up tearing the whole thing apart to switch out the entire plumbing system someday.
Thanks for all your help!
Old 04-12-2008, 05:32 PM   #7
Lawton , Oklahoma
Looks great, good job!
Rodney
Old 04-12-2008, 08:49 PM   #8
Profile:  1967 26' Overlander
Winston Salem , North Carolina
Your repairs look great.
I have friends who have used Sea-tech with excellent results.
I'm going to replace all the old cooper with Pex and Sharkbite fittings.
Bought most of mine off e-bay, My Home Depot sells out too quickly.
Restoring an older model is sooo much fun.
Greg
Winston Salem, NC
WBCCI 5218,
1967 Overlander International.
FTC 15771
1979 Avion 30ft rear bath
Silverwanabe is offline   Reply With Quote
Old 04-12-2008, 09:03 PM   #9
Commercial Vendor
lewster's Avatar
Profile:  2006 19' International CCD
Marco Island, FL , Hood River, OR
You guys are on the right track!
I use Sea-Tech fittings to link PEX to any similar size material with no problems......copper, CPVC or ......polybutylene (if you have it and don't remove it!!!!!) Been using the stuff for 3 years now and NO CALL-BACKS for leaks!!!!
Shark-Bites are also very good, but a little more expensive and a little more difficult to connect in really tight spaces.
It's all good with the new stuff!!!!!!!!!!!
Lew Farber - contact
Certified Master RV Tech
BACK IN THE 'HOOD' FOR A WHILE !!
"Laissez Les Bon Temps Roulez"
www.islandmetalworks.com
WBCCI #1032/VAC (assoc) #1032
AIR # 10325
CHARTER MEMBER: FOUR CORNERS UNIT
Old 04-13-2008, 05:19 PM   #10
OregonArgy's Avatar
Gresham , Oregon
One quick warning. When I went to Lowe's, SeaTech isn't sold under the name SeaTech. Their products were sold in packages under the name Watts WaterPEX, but clearly have SeaTech on the fittings inside the plastic envelopes.
Old 05-01-2008, 09:05 PM   #11
Profile:  1973 Argosy 26
Orlando , Florida
I have used pex alot in residential building and never had any problems. I will be converting mine over when I get back to all my dads tools (his pliers) b/c if I remember correctly the cripping pliers are ridiculously expensive everything is reasonable and works excellent. Sometimes in tight places it can be tricky. They make plenty of fittings to connector it to different types of material as well.
basecmp is offline   Reply With Quote
Old 05-01-2008, 10:50 PM   #12
Profile:  1972 25' Tradewind
Madison , Wisconsin
I rippied all of the old supply side plumbing out & am replumbing with pex. So far so good.
Smokin Camel is offline   Reply With Quote
Old 05-05-2008, 08:40 PM   #13
OregonArgy's Avatar
Gresham , Oregon
In going through the supply side plumbing, now I've tried Sharkbite AND SeaTech. The SeaTech is at Lowe's and I VERY MUCH dislike Lowe's (for many reasons, all to do with problematic customer no-service). One day they were out of a 1/2" T of the SeaTech. So I thought, "What a great opportunity to try out Sharkbite at Home Depot!" The Sharkbite, though brass and extremely sturdy, were just a tad more complicated to work with and were about 30% more expensive ($8 a fitting adds up REALLY fast!). I'll probably stay with Sharkbite, though, because of the whole HD/Lowe's comparison.
PEX is definitely the only way to go for new applications or repairs.
Pingbacks are On
PEX Conversion Sundance Fresh Water Systems 18 07-12-2007 04:12 PM
Copper vs. PEX ckeysor Fresh Water Systems 19 07-11-2007 12:03 PM
Re-plumbing 1/2 or 3/8 PEX Gen Disarray Fresh Water Systems 5 03-04-2007 08:52 PM
pex crimping rama777 Fresh Water Systems 5 10-28-2006 04:44 PM
A-frame to Body "Transition Gussets/Fillers" jaco Parts Archive 5 03-17-2004 03:51 PM
SEO by vBSEO 3.1.0
