Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures
Old 09-12-2009, 02:40 PM   #1
Profile:  1979 31' Sovereign
Winnipeg , Manitoba
how to remove this fitting?
During our last camping trip the plumbing started leaking and it was very wet around the toilet area. I discovered the leak to be coming from the elbow fitting that goes into the hot water tank. It's located next to the water pump compartment by the toilet... I disconnected the hose already but I don't know how to remove the broken fitting. I'm all ears. Here are some pictures.
ID:	87078   Click image for larger version
ID:	87080   Click image for larger version
SnoSheriff is offline   Reply With Quote
Old 09-12-2009, 03:02 PM   #2
vswingfield's Avatar
Profile:  1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
Turn it counter-clockwise. Vise-Grips used carefully might be a good candidate (I wouldn't recommend them for most plumbing tasks, but this fitting is already trash).
If the threads break off, you should be able to whittle the plastic away with a knife. Concentrate on one small area to create a groove that you can just see the threads from the fitting in the tank. Then start prying the rest off from the edges of the groove.
Good luck!
Vaughan
A sixth sense (I lack the other five) tells me that I am in serious difficulties. Oscar Levant
Old 09-12-2009, 03:07 PM   #3
HowieE's Avatar
Profile:  1991 34' Excella
Princeton , New Jersey
Images: 11
That should be a threaded fitting. I would remove as much as you can from the area. pump, water filter, and other hosing to give you good access.
You will have to cut off some of the vertical pipe off the fitting to get clearance for it to turn on the lower side.
WBCCI 12156 AIR 3144 WDC unit
1997 6.5 Diesel Chevy 2500 See my pages mysite.verizon.net/vze54tx9/
and mysite.verizon.net/vze54tx9/kayak/
1991 34 ft. Excello +110,000 miles, new laminated flooring, new upholstery, new 3200 lbs axles
Old 09-12-2009, 03:11 PM   #4
1967 24' Tradewind
Images: 32
Ditto,
Thanks HowieE, I left that part out somehow.
The rest addresses a bad scenario that, with any luck, will not come up at all.
Vaughan
Old 09-12-2009, 04:50 PM   #5
Winnipeg , Manitoba
Using your advice I was going to cut it off. But while wiggling the fitting extension it simply broke off. It gave me enough clearance to turn the fitting. I had it out within 5 min. Thank you very much.
Off to the plumbing store to find the replacement
What is this nozzle fitting? Mrcrowley General Repair Forum 3 05-17-2009 10:35 AM
Thetford fitting goransons Waste Systems, Tanks & Totes 0 04-28-2008 08:19 PM
Fitting new converter Skater Batteries, Univolts, Converters & Inverters 8 03-14-2008 04:19 PM
Help! 1/2 x 3/8 x 3/8 push fitting glacierrunne Fresh Water Systems 7 06-05-2006 11:04 PM
fitting a 'Fantastic' fan in a 66 hickam Roof Vents, Skylights & Fans 4 04-18-2005 12:07 PM
