Old 04-12-2015, 02:54 PM   #1
SteveH's Avatar
Common Sense , Texas
Is this operating on electricity, or gas?
Regards,
Steve
Old 04-12-2015, 07:14 PM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Not sure what you mean by "too hot".
MICHAEL
Old 04-12-2015, 07:15 PM   #3
AWCHIEF's Avatar
Images: 33
You can buy an adjustable thermostat to replace the fixed unit.
MICHAEL
Old 04-13-2015, 11:54 AM   #4
gsmithii's Avatar
2013 30' Flying Cloud
Virginia Beach , Virginia
Hot water too hot.
Assuming that you are using an Atwood hot water heater you may have a failed thermostat with water temperature controlled by the Emergency Cutoff sensor. Try this video. The troubleshooting can't hurt.
When you confirm that the thermostat is failed you will replace the thermostat and ECO as a pair. If I can do it just about anybody can do it.
Much success.
Skip
Speed is Life . . . guidance is optional . . .
The Traveling Circus: 2013 Flying Cloud 30A; 2006 Chevy Duramax Crew/LWB
Air #42313 TAC VA-7 WBCCI #1290
gsmithii is offline   Reply With Quote
Old 04-13-2015, 01:36 PM   #5
knunut's Avatar
Chgo. N.W. Burb's , Illinois
Same problem in our 2007. From what i understand the temp "normal" can be 140 ,which still seems Hot. However our temp shot pass 140 .
Tech replaced the sensor kit (Both as mentioned above) and problem fixed.
knunut is offline   Reply With Quote
Old 04-13-2015, 01:41 PM   #6
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
Certainly check out the thermostat and the general operation. If you are checking at a mixing faucet is is possible the cold water is partially blocked from sediment. The water can get scalding hot and it is a matter that needs to be addressed.
Old 04-13-2015, 02:18 PM   #7
2007 28' Safari SE
Deland , Florida
gas
Jeffg24 is offline   Reply With Quote
Old 04-13-2015, 02:19 PM   #8
2007 28' Safari SE
Deland , Florida
burning hot
Old 04-13-2015, 03:04 PM   #9
KJRitchie's Avatar
2008 25' Classic
Full Time , Texas
Can these two thermostats cause intermittent issues?
I had filled up my water system after taking my AS out of storage over the winter and filled up the lines and water heater. I ran all the faucets on both cold and hot to get the air out. Then I went out for the weekend. The AS was connected to city water at the campsite. I noticed when running the water heater on gas it seemed to be running longer than normal. I ran some hot water from the kitchen and it seemed hotter than normal. I let the hot water run in the kitchen sink and more air came out. Ran the bath faucet and more air. Finally both faucets stabilized. After that the water heater seemed to shutoff normally.
I wonder if I should replace the two thermostat sensors. I have the Atwood 6 gal gas/electric electronic ignition model.
Kelvin
Too Hot Water in Shower wolverine Sinks, Showers & Toilets 14 10-12-2017 02:09 PM
How hot is too hot ALí UM- MONEY On The Road... 24 06-17-2013 05:52 PM
New AS Water way too hot! Gringo Water Heaters, Filters & Pumps 36 07-14-2012 04:00 PM
Hot water too pot.. Sodbust Fresh Water Systems 2 03-25-2012 02:15 PM
Help!! Hot Water Heater Flame is Too High emmy Water Heaters, Filters & Pumps 3 03-02-2006 02:29 PM
