I know there has been a lot of controversy in the forum about the potential use of LP tankless water heaters that are not fully approved by a US based agency for use in a travel trailer. The low cost of many of the units that are available these days however is very appealing. I admit that I am taking a risk with the approach that I have decided to take but it is a very carefully calculated one. For one thing I have decided to mount my water heater on the outside of my Airstream rather than opting for one that could be mounted on the inside. There are some that have direct vent connections and bring in their combustion air from the outside but for safety reasons I have decided to keep it all outside. The unit that I purchased a while back is in the link below. This vendor still seems to have the best price on this unit too by the way.
Eccotemp L10 High Capacity Tankless Unit - Lowest Prices GUARANTEED!!
Camping World is selling this model now too along with its smaller brother. This model has a capacity of 69,000 BTU at 3 gallons per minute. It is designed for an outside installation and has a stainless steel rain hat on it. I opened up the case a while back to see what was inside and was impressed both with the units overall simplicity and the fact that there is absolutely nothing that can bounce around when the trailer is in motion. It is true that it is manufactured in China. The company that builds it builds something like 1 million water heaters per year though.
When I first got the heater I wanted to see how it worked. I built a little stand for it and hooked it up to the propane tank from my BBQ with the included hose. First I tried hooking up the unit with a garden hose. Later I also hooked up the water pump that I am using to pump water through the radiant heating loops. I just had to put 2 D-size batteries in the battery box on the unit to activate it. When I started up the water flow either from the pump or the hose the water heater fired up right away and started heating water. Stop the water flow and the water heat shut off right away too. It works just fine.
The one issue that I am going to have to see how it plays out is that there is a 17 minute safety cutoff mechanism built in that turns off the water heater if the unit has run for 17 minutes continuously. This is a good safety feature but could be an issue for me if the unit needs to be on for more than 17 minutes at a time for the radiant heating. If this does become an issue I will have to add a simple timer that shuts off my hot water pump for a minute or so to reset the 17 minute timer. That will not be that hard to do but may not be necessary so I will wait and see.
I thought long and hard about where to mount the unit on the outside. I would actually like to mount it on the back of the trailer but the outward slope of the back wall is way to steep to be able to mount it there without mounting it further back than I wanted. I would also like to mount it on the street side of the trailer in the area where my frig and propane generator are located. There are no windows in that area and it would be closer to where I need the hot water. Having the unit sticking out on the side does not seem like a good idea at all. I even considered mounting it in a way that I could take it off for travel and put it back on when needed. That might not be a bad way to go if you don't mind the hassle but I finally decided against that. I thought about creating a recess on the side of the trailer to mount the unit it so that it would not stick out into oncoming traffic. That seemed like too much work but could also be an OK place if you feel up to the challenge. I finally decided to mount my unit up on the front of the trailer. I know the issues. It will be near my propane tanks but not really any nearer than my BBQ burners are to its propane tank. It will also be mostly below the front window. The chimney will likely come up above the bottom of the window. My plan is to just make that window fixed so that it can not open and collect combustion fumes. I will be mounting the unit off center toward the curbside to get as much distance as I reasonably can from the propane tanks and to keep it away from the electrical umbilical cord that connects in the center. I am also going to install a rock guard around it using perforated aluminum sheet metal.
I have not yet installed my water heater in the above mentioned location but will be doing so soon. Once I do I will include a photo or two. I did however run the two PEX lines that will connect to the water heater out the front end of the lower part of the body in a place that will be close enough to run braided metal connection hoses to the bottom of the water heater. The attached photo shows where these connection points are now. At the moment I have a flex hose just connected from one fitting to the other so I can test out the rest of the water system with out hooking up the water heater just yet. As you can see from the photo I have a little clean and painting to do on the trailer tongue.
Malcolm
