Old 09-14-2019, 01:03 PM   #1
andysherard
greenville , thomassherard
Hot Water Heater on Battery
I have a 2018 27FB. This is our first time boondocking. We're having trouble with the hot water heater. It acts like it is trying to ignite but nothing. It was working fine the last time we were hooked to power. Battery seems to be fine and fuses seem good. Any ideas?
andysherard is offline   Reply With Quote
Old 09-14-2019, 01:10 PM   #2
Long Island , New York
Welcome to the forum!
I assume you are trying to run the "water heater" on propane? ["trying to ignite"] Do your other propane-fired appliances work, like the cook top burners, and fridge?
If so, the propane line to the water heater could be crimped or damaged in some way. Another option would be that the water heater's control/circuit board is defective.
https://www.google.com/search?q=wate...=airforums.com
2018 search term added: https://www.google.com/search?ei=bTx...4dUDCAo&uact=5
What brand is your heater, Atwood maybe? Seems like 2018 was not a good year for water heater control boards. If all of your propane-fired appliances are not working, you might have a bad regulator at the tanks:
https://www.google.com/search?q=prop...=airforums.com
If you could provide more details, folks will be able to give better advice IMO.
Good luck,
Peter
PS -- What is your battery voltage reading on the monitor panel? If it is below 12.1 volts +/- your water heater may not want to light, due to low voltage IMO. Are all your other 12-volt functions working OK?
Old 09-14-2019, 01:24 PM   #3
AirMiles's Avatar
2018 27' Globetrotter
Apollo Beach , Florida
The first thing I would do is light my propane stove to make sure there is no air in the line. Does the stove work properly? If the stove works, and the water heater still won't light, then I would start looking inside the water heater outside panel for loose wires. A loose wire on my controller board made my water heater not work on electric or propane. I reconnected the wire and all worked fine.
Start with the simple things. Is there propane? Is there a loose wire? And then move up to more difficult possibilities, like control boards, if the simple things don't fix it. Since its trying to light, I think its a propane problem and not a board problem.
2018 Globetrotter 27Q, 29 nights 4,435 miles, 600W Solar, PD4655L, Duracell EGC2 Batteries, ProPride, 16" Michelin's, Champion 3400W Dual-Fuel, 2019 F250
Sold: 2017 Flying Cloud 25FB, 316 nights 40,150 miles, 400W Solar
Sold: 2013 Casita SD17 89 nights 16,200 miles
AirMiles is offline   Reply With Quote
Old 09-15-2019, 06:09 AM   #4
andysherard
Thanks for the responses. All other propane appliances are working. I can spell propane at the water heater. Sounds like igniter is trying to work. Battery is at 11.8.. I’ve looked at wires etc around the panel. I’m thinking it’s a battery issue at this point. We’ll be hooking back up to shore power tonight. I’ll keep you posted.
Old 09-15-2019, 06:39 AM   #5
fran&frank's Avatar
2016 27' Flying Cloud
Hartsburg , Missouri
You've run your battery down below the advisable state of charge so first step should be to get it charged.-- Frank
Frank & Fran
2016 27' FC FB with 400 W solar
2016 Ford F150 EcoBoost
Equalizer Hitch
fran&frank is offline   Reply With Quote
Old 09-15-2019, 09:10 AM   #6
Half a Rivet Short
Carlisle , Pennsylvania
Hi
The battery normally should read above 12.1V at all times. We are headed into the colder part of the year, you may want to bump that number up a bit. The magic number is about 12.6V rather than 12.1 if it's in the 30's (F) out. Since the stock monitors can be a bit off (and you have voltage drops) a DVM at the posts of the battery is the thing to trust.
If you have propane *and* the burner never lights (as opposed to lights and then goes out) first thing to check is for a spark at the igniter.
Old 09-15-2019, 10:38 AM   #7
1985 31' Excella
st. Paul , mn
A fully charged FLA - Flooded Lead Acid , battery is 12.75 after rest - rest is some time after fully charged , about a min. 1/2 hr. after charge is removed .
Some AGM , Gel etc. have a higher rested / charged voltage .
85 Excella , 31' , electric brakes , R. twin [ would like it to be a single ] , future upgrades , composting toilet [ replace black water tank with a 2nd fresh ] , solar power , instant hot water heater .
Tow 94 Dodge Ram , 4x4 , Cummins , AT .
JohnTF is offline   Reply With Quote
Old 09-15-2019, 10:44 AM   #8
Annapolis , Maryland
Check the exhaust pipe
I had a similar problem with my water heater. The cause was a mud dauber nest in the exhaust pipe for the heater.
Symptoms were propane smell near the heater, but no hot water.
Remove the covers and look for dauber nests inside the pipes. The pipes can be removed and cleaned.
We installed a mesh screen over the exhaust, which has worked well.
rhpeahl is offline   Reply With Quote
Old 09-15-2019, 12:31 PM   #9
Silver Star
rucos's Avatar
1970 23' Safari
Victoria , British Columbia
battery is very low and could be your problem. I wouldn't let the battery get below 12v.
Time for the generator hook up I think.
rucos is offline   Reply With Quote
Old 09-16-2019, 06:35 AM   #10
andysherard
Thanks All. We hooked to shore power yesterday. The electric hot water is working fine.
However when I try to switch to propane, the igniter does not appear to be sparking to light the propane. The electric switch for the hot water is off when I'm trying to use the propane. The 2 amp fuse appears fine. Wire connections appear good. I can smell propane and actually manually lite the tank yesterday but the flame went out after +/- 3 seconds. Thoughts? Thanks
Old 09-16-2019, 07:24 AM   #11
Rivet Slave
Rocinante's Avatar
2014 27' FB International
Green Cove Springs , Florida
What you described before sounded like a battery issue. Maybe something else since it now refuses to ignite while on shore power. Does your stove stay lit when you turn on a burner? Does your fridge work on propane?
Battery advice in case it's helpful: Either your batteries have a problem (use a battery tester to check each cell after fully charging and then letting them rest for an hour), or you are simply overly discharging your batteries. If your battery is testing below 12.1 volts, you are way into the dead zone. Every time this happens, you damage your batteries, so don't do that if there's any way to avoid it.
Things that can help while dry camping:
* Be frugal in your use of power. Anything you turn on shortens your dry camping trip. Don't run anything you don't absolutely have to run. That short list includes the fridge, the water heater (on propane) only when needed, and occasional use of water (e.g. the water pump runs). Beyond that you're camping in extreme luxury and your dry-camping stint will be significantly shortened.
* Adding solar panels and a controller that will actually charge your system. Your dealer has no real understanding of solar, so either DIY or find a place with solar expertise that's done Airstreams before.
* Bigger batteries and/or switching to Lithium (LiFePO4-type) batteries. There are plenty of threads here that discuss bigger battery options. Lithium batteries are expensive, but provide far more power for the weight. Switching to Lithium batteries usually also means switching out your charger, so that's a fairly big shift. We went the bigger battery route, which helped somewhat, before finally upgrading to Lithium.
Good luck and happy camping!
Rocinante is our 2014 International Signature 27FB
Old 09-16-2019, 08:24 AM   #12
Dan and Liz's Avatar
1987 25' Sovereign
Fort Collins , Colorado
I suggest you remove and clean the igniter/flame sensor probes with an abrasive (emery cloth, sand paper or ?), including removing/cleaning the base of the bracket they mount on. Lack of a good electrical connection/ground can cause the unit to not sense the flame, which will shut off the gas after a short while — hence flame goes out. Your symptoms indicate that could be the issue.
Alumacoot
"I'd rather be happy for just one day than miserable for the rest of my life."
Dan and Liz is offline   Reply With Quote
Old 09-19-2019, 06:00 AM   #13
andysherard
I called AS and they helped confirm it was most likely the circuit board. I then called Dometic. After giving them the serial number and model number they quickly agreed to mail me a new circuit board. As noted in other post there was an issue with the circuit board in 2018 models.
Thanks again for the responses.
Old 09-19-2019, 06:46 AM   #14
Thanks for the update.
Peter
Hot Water Heater Works But No Hot Water Althea Water Heaters, Filters & Pumps 6 04-16-2016 09:45 AM
being frugal with hot water best ways to manage hot water cost lbdesign Full-Timing, Winter Living & Workamping 23 12-17-2015 09:14 AM
Hot hot hot aluminum! 58cruzer General Repair Forum 23 06-24-2013 01:08 AM
AC just quit working and it's Hot Hot Hot!!! SaabLover Furnaces, Heaters, Fireplaces & Air Conditioning 9 07-27-2010 09:03 PM
hot water water on demand with a with a normal water heater Frank's Trailer Works Water Heaters, Filters & Pumps 3 09-25-2007 12:24 AM
