Old 03-27-2014, 08:46 AM   #1
kiddoc1's Avatar
2008 28' Safari SE
Tryon , North Carolina
Hot water heater not working properly
I just de-winterized my 2008 28' Safari SE. The hot water seemed to work fine for a while. Now when I open the faucet for hot water, very hot water comes out for about 30 seconds and then become barely lukewarm. The only switch I know of is in the bathroom and I do not see the red light come on when I toggle it. I'm certain the flame is coming on since the water is hot to start with. I checked the position of the valves and they seem to be OK.
As a follow-up question, assuming I get it working again: is there any way to adjust the water temperature.
Frank & Debbie DiBona
2008 Safari SE 28
2013 Ford Expedition EL
http://www.streamingtogether.blogspot.com
kiddoc1 is offline   Reply With Quote
Old 03-27-2014, 08:53 AM   #2
richw46's Avatar
Lexington , Kentucky
Sounds like it was on for a while, then quit. Hot water rises to the top so you got some, then when the fire went out the rest of the water was in varying degrees of hot.
If the heater has worked until now and you just de-winterized, clean everything around the pilot and burner assembly. Follow the owner's manual for cleaning spider webs out of the burner tube. If the pilot isn't staying lit then it may be a bad thermocouple.
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE
richw46 is offline   Reply With Quote
Old 03-27-2014, 09:00 AM   #3
Wise Elder
Jammer's Avatar
2010 30' Classic
It is likely that you left the bypass valve, used for winterizing, open. Closing it should clear up the problem.
Old 03-27-2014, 09:05 AM   #4
Silver Otter's Avatar
2011 31' Classic
Nellysford , Virginia
Images: 8
Frank,
Be sure, sure, sure about the valve positions. I failed to close the cross-over valve one spring and my wife got in the shower. When that small bit of hot water stopped, you can bet I heard about it (and I think I was outside at the time) . . . eh?
Linda Heuer. President Shen. Valley Unit
Greg Heuer, 2nd VP Shen. Valley Unit
2011 31' Classic Ltd. - The Silver Otter III
2013 GMC Denali 2500HD 6.6 DuraMax - Sierra Blanca
TAC VA-18 | WBAC 1927 - Shen. Valley Unit 149 | AIR 53869
with Corey, the Norwegian Forest Cat
Silver Otter is offline   Reply With Quote
Old 03-27-2014, 10:42 AM   #5
kiddoc1's Avatar
2008 28' Safari SE
I understand the the valves should be aligned in the same direction as the water line they are on. Is that right? Should the bypass valve be in the same alignment?
2008 Safari SE 28
Old 03-27-2014, 10:44 AM   #6
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
No.
Old 03-27-2014, 04:37 PM   #7
kiddoc1's Avatar
2008 28' Safari SE
Thanks everyone! I did have the valve in the wrong position and now everything is working.
Frank
2008 Safari SE 28
Humphrey gas light not working properly bmklawt LP Gas, Piping, Tanks & Regulators 6 12-05-2011 09:58 AM
AC just quit working and it's Hot Hot Hot!!! SaabLover Furnaces, Heaters, Fireplaces & Air Conditioning 9 07-27-2010 09:03 PM
New Water Heater Not Working Properly BobbyWhitit Water Heaters, Filters & Pumps 8 04-18-2010 01:10 PM
Is new converter working properly? tphillips Batteries, Univolts, Converters & Inverters 1 03-10-2009 08:14 PM
Water Pump Not Working Properly? 74SovereignInt. Water Heaters, Filters & Pumps 8 11-11-2002 12:44 PM
