Old 11-11-2015, 07:58 AM   #29
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
I put one of the plugs with the valve in last fall when I winterized. This fall when I tried to open it the valve would turn but would not open. Going back to a solid plug. Hope I can fine one in stainless but will use brass and nylon tape if not.
Old 11-11-2015, 11:28 AM   #30
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
I bought a boiler drain valve part #6851687 from Menards. Screwed it in. Now all I do is open the valve to drain the water heater.
TG Twinkie is online now   Reply With Quote
Old 11-11-2015, 03:29 PM   #31
1998 30' Excella 1000
Livingston , Texas
When I remove the plug, I get a full 3/4" diameter opening to help flush deposits from the bottom of the tank. With a ball valve, maybe 1/2" diameter opening (depending on manufacturer), with a gate valve even less. I think more effective flushing of the tank is worth the 30 seconds (or less) that it takes me to remove the plug with a 15/16" socket and extension on my wrench. If you're only in areas with soft water, then maybe not an issue.
Siegmann is offline   Reply With Quote
Hot Water Heater Works But No Hot Water Althea Water Heaters, Filters & Pumps 6 04-16-2016 09:45 AM
Bowen B10G water heater drain plug lebolewis Furnaces, Heaters, Fireplaces & Air Conditioning 3 09-20-2008 11:49 AM
Needed, drain plug for hot water tank! wacnstac Fresh Water Systems 8 10-16-2007 08:22 PM
