Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures
Old 04-24-2018, 04:23 PM   #1
Sackville , New Brunswick
Hot water Bypass (first time de-winterizing)
Hey, we bought an Airstream Sport 16 from you last year and we are getting it out of storage. And are doing all of the de-winterizing.
My problem is the hot water bypass. I can't figure out the correct config, Enclosed is a picture of my pipes in the closet. Can you tell me the:
Normal config of valve 1, 2 and 3
1) the valve attached to red and white /hot and cold pipes
2) the valve attached to nothing but hot pipes
3) the valve attached to nothing by cold pipes
the winter bypass config of valve 1,2 and 3
I just need to know which should be a) parallel/along the pipe or b) perpendicular/at a 90 degree angle to the pipe
Jonathan
Maritime_Jon is offline   Reply With Quote
Old 04-24-2018, 04:46 PM   #2
Retired.
. , At Large
Hi. Not sure who you are addressing this to, maybe you were trying to email your dealer?
There is no photo in your post.
Old 04-24-2018, 04:52 PM   #3
TheGreatleys's Avatar
1974 27' Overlander
Baltimore , Maryland
Jonathan
Parallel is open. Perpendicular is closed. This is true of all ball valve designs I've ever seen.
From your description, #1 is the bypass valve. #2 is the outlet and #3 is the inlet.
To place the heater back in service, open #2 and #3, and close #1.
To bypass for storage, close #2 and #3, and open #1. Don't forget to drain your water heater tank after bypassing it to prevent the tank from rupturing over the Winter.
TheGreatleys is offline   Reply With Quote
Old 04-24-2018, 09:17 PM   #4
Moflash's Avatar
2007 28' International CCD
Springfield , Missouri
Your owners manual is your friend.Didn’t get one on delivery?No worries Airstream has them online.No charge.
Why bypass the water heater when winterizing? Sweendk Water Heaters, Filters & Pumps 2 10-25-2017 09:58 AM
Hot Water Bypass kirbyjunewri 2011 - 2015 International 2 10-07-2013 11:41 AM
Hot water bypass - 1996 Excella SteveFE Plumbing - Systems & Fixtures 4 11-14-2012 12:53 PM
Hot Water Bypass Lumatic General Appliance Topics 4 10-09-2012 05:57 PM
Help, no hot water heater bypass in my 1975 31' Sovereign ShinyTwinkie Winterizing, Storage, Carports & Covers 5 11-30-2008 05:52 PM
