Old 10-13-2012, 03:23 PM   #1
1996 28' Excella
Banks , Oregon
Hot water bypass - 1996 Excella
I just bought a used 1996 28 foot widebody Excella. I can ony find one valve to bypass the waterheater. The two valves for the run around aren't in the waterheater compartment. Is there another place I could look to find them or does this unit only have the one?
SteveFE is offline   Reply With Quote
Old 10-13-2012, 04:35 PM   #2
retired USA/USAF
2001 30' Excella
Somerset , New Jersey
I don't know if / when they began to install them at the factory. Our '85 did not have a by-pass but our newer '01 does have it. I think it's a toss. You probably just don't have it. If by WH compartment you mean the outer door it wouldn't be there. In the lower cabinet in the bathroom is where you'll find them if you got one. Look for the incoming line and outgoing lines. That's where it'll be if it's present.
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
polarlyse is online now   Reply With Quote
Old 10-13-2012, 05:32 PM   #3
Skater's Avatar
1995 30' Excella
Bowie , Maryland
Our '95 does have the bypass, so I'd expect a '96 to have it too. Odd. In mine they're right next to the water heater as you'd expect.
1995 Airstream Classic 30' Excella 1000
2014 Ram 2500 Crew Cab with Cummins 6.7L Diesel
Sold but not forgotten: 1991 Airstream B190
Sold: 2006 F-250 6.0L Powerstroke Supercab
Skater is offline   Reply With Quote
Old 11-14-2012, 11:33 AM   #4
xitjustice's Avatar
1994 28' Excella
Clearwater , Florida
I second that question with more info..
I also have a 95 excella 30'.
I attached a couple pics of what the real life view is for me. I just got the trailer recently and I am currently using it,.. so I haven't made it to the winterizing/storage procedures yet.
The picture is color coded for future reference in this post. If you can identify what color goes to what I would appreciate it.
From the manual: To by-pass the water heater for winterizing, close valves A and C and open valve B. Picture of lettered valves taken roughly from airstream my airstream manual.
To me, Looks like it would be colors red and green are A and C.
thanks hope this helps
Name:	water heater forum.jpg
ID:	172730   Click image for larger version
Name:	Water heater forum pic 2.jpg
xitjustice is offline   Reply With Quote
Old 11-14-2012, 12:53 PM   #5
Skater's Avatar
1995 30' Excella
Bowie , Maryland
Red is A, yellow is B, and green is C.
The valve on the floor directly under the water heater is for allowing water past the pressure valve/check valve so you can use the outside spigot when you're running on the pump. That valve would normally be closed when you're on city water. (I just noticed this weekend ours has been open for the entire season. Oops. Oh well.)
Hot Water Radiant Heat - My Installation malconium Plumbing - Systems & Fixtures 82 01-30-2012 01:40 PM
Shower hot water RosiesGuy1 Sinks, Showers & Toilets 3 12-31-2011 04:25 PM
Water tank-weep holes-mystery leak(s). Gator113 Fresh Water Systems 9 09-21-2011 02:39 PM
'74 Trade Wind..broken water line, continued Ameliasdad Fresh Water Systems 1 04-07-2011 01:10 PM
