Old 08-20-2019, 10:10 AM   #1
2019 30' Classic
ST PETE BEACH , Florida
hot and cold water
Well here is a weird one....out of the blue the hot and cold water valves switched. One day I turned on the faucet to cold and hot water came out and turned on hot and cold water came out. Called three dealer service departments and they all have never heard of this. If it was a bad water control valve then the water would be hot, cold or luke warm. It really doesn't matter because it all works fine, just backwards from how it was working.!!
alannewcomb1 is offline   Reply With Quote
Old 08-20-2019, 11:02 AM   #2
Slide Out Society #001
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
hot and cold water
Solar heating of the cold water supply hose heated it up you got first flow thru cold faucet.
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Carslile Actuator, Equal-i-zer, Dill TPMS. Campfire cook.
GCinSC2 is offline   Reply With Quote
Old 08-20-2019, 01:42 PM   #3
abqdor's Avatar
2016 25' Flying Cloud
Albuquerque , New Mexico
This happened to us after winterizing. We were getting more hot out of the cold and very little of anything from the hot side. I followed the various threads and narrowed things down to the mixing valve perhaps being clogged. So I pulled the mixing valve, but didn't find any screen clogs. What I did find was a small check valve in the water heater port that had become dislodged and was apparently blocking the correct flow from the heater. After getting the check valve back in the correct place everything started working again.
How it got that way, I don't know. I winterize with air, but take the heater out of the system with the bypass valve before winterizing. There are some pictures of what I found in the thread below.
http://www.airforums.com/forums/show...errerid=103283
'17 Ford F-150 Ecoboost, max tow package
'13 GMC Yukon Denali 6.2L V8
'04 GMC Yukon SLT 5.3L V8
abqdor is offline   Reply With Quote
Old 08-23-2019, 03:45 PM   #4
GCinSC2's Avatar
Curious what was the problem and it’s solution?
S/OS #001
Hot water in the cold water lines? lbdesign Fresh Water Systems 21 02-03-2017 12:57 PM
Heated water hose that covers hot and cold climate? spreadmywing Fresh Water Systems 9 09-16-2016 02:20 PM
Heat Pump - How cold its too cold? VeggieBullet Furnaces, Heaters, Fireplaces & Air Conditioning 7 01-09-2014 06:03 PM
Hot hot hot aluminum! 58cruzer General Repair Forum 23 06-24-2013 01:08 AM
AC just quit working and it's Hot Hot Hot!!! SaabLover Furnaces, Heaters, Fireplaces & Air Conditioning 9 07-27-2010 09:03 PM
