Old 03-19-2012, 07:54 PM   #1
1975 31' Sovereign
Cleveland , Georgia
Hooking toilet back up
When we bought our 75 land yacht the toilet had been unhooked. We see where the toilet water line screws into the back of the toilet but we can not find a place to hook the other end of the line to. We took the paneling off behind the toilet but can not find a place to hook it up. Is it hidden? Does it make a difference that the water heater is hooked up next to the toilet?
Cassarey is offline   Reply With Quote
Old 03-20-2012, 04:10 AM   #2
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
It should be in the cabinet next to the toilet - look for a capped off shut off valve. You should use a new flange seal, liberally coated with top and bottom with plumbers silicone grease to reseat the toilet.
We used a 5 foot flexible stainless line to reinstall ours. It was much easier to install that way as your not having to fight rigid copper to get it back into place. Some dishwasher feed line kits will have the appropriate brass fittings make the connections. Otherwise, you'll need to pick up two fittings to make the flex line connections. Have fun...
Old 03-20-2012, 04:18 AM   #3
Ludowici , Georgia
Images: 43
welcome to the fourm send pic of your Airstream would to see the inside we have a 74 land yaught 31 ft
Stoney is offline   Reply With Quote
Old 03-20-2012, 08:23 AM   #4
1975 31' Sovereign
Cleveland , Georgia
I will post pictures as soon as we are done with renovations. She was not in very good shape so we are putting a lot of work into her.
Source for old thetford toilet parts? bbqmama Sinks, Showers & Toilets 13 09-18-2015 01:42 AM
Back wall curvature TinkersMom General Interior Topics 7 03-20-2012 05:16 PM
Need some parts for a window clean up ND10CentCan Windows & Screens 43 03-19-2012 05:35 PM
water heater/toilet question Cassarey Plumbing - Systems & Fixtures 2 03-13-2012 10:09 AM
