Old 08-12-2014, 11:31 AM   #1
1984 27' Airstream 270
On The Road , USA
Help With Mystery Leak
I have an '84 Sovereign. I noticed a small amount of water weeping up between the slats of my faux wood vinyl floor between the end of the bed and the wardrobe area. Last night, I was lying in bed and it was very quiet and I started to hear the drip, seemingly right underneath me. I got up, shut off the water and the drip stopped. Today I pulled up the bed and there is no evidence of a leak, But when I turned the water back on the weeping began anew. Any ideas?
airuker is offline   Reply With Quote
Old 08-12-2014, 11:52 AM   #2
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
The water heater is just to the rear of the wardrobe?
Old 08-12-2014, 12:08 PM   #3
On The Road , USA
No, the water heater is at the foot of the bed on the left side of the trailer (driver side).
I checked the water heater and there are no obvious leaks, but some the water from the intake/water heater is weeping under the floor. Jim
Old 08-12-2014, 12:21 PM   #4
clancy_boy's Avatar
2003 22' International CCD
Kiln , Mississippi
Images: 8
One - it's a pressurized water issue. GOOD, you can control that and the trace is easier than a skin leak. Just follow all the water lines as best you can until you locate the leak. What's bad is you have to wait to find it to use the water system. Access can be a real pain in locating these. Post a floor plan or some pictures. All of the furniture can come out - it's not easy but they did set it up to access all the fittings from the inside. Is this the location of the outside hook up area. mine leaked at that connection.
Michael & Tina with Layla and Preston BZ
The family has grown.
2003 22' INTERNATIONAL CCD
Old 08-12-2014, 12:47 PM   #5
1973 29' Ambassador
Seattle , Washington
Isn't there a pressure regulating valve in some units in that location. try searching the forums for that and see if the pictures of the location look like it might be yours.
dcheshire is offline   Reply With Quote
Mystery leak - NEED HELP finding it pgreenx Plumbing - Systems & Fixtures 2 05-30-2012 06:44 AM
Mystery Door Leak - Help Needed MDSilverado Leaks - Weatherstrips, Gaskets, Caulks & Sealants 17 02-14-2011 01:11 PM
Water leak mystery... TennisMan 2007 Safari SE 1 06-03-2007 06:40 PM
Mystery Leak Excellaphant 1987 - 1989 Excella 10 12-21-2005 08:57 AM
Mystery coolant leak PeterH-Airstreamer Mechanics Corner - Engines, Transmission & More... 11 06-06-2005 11:34 PM
