Old 06-16-2015, 03:59 PM   #1
1975 31' Sovereign
Poulsbo , Washington
Help! (insert cursing) old copper pipe is 1/32nd inch bigger than standard PEX
My husband is tearing his hair out trying to fix 3 leaks under kitchen sink in 76 Sovereign, probably busted when pipes froze.
New fittings won't attach to the copper. It's too wide, just a hair. The cursing is getting intense.
He bought PEX to replace long piece under the mid section bed, but can't hook them up.
Any suggestions? He's got his metal grinder out but thought I'd ask before somebody hurts themselves
casbc is offline   Reply With Quote
Old 06-16-2015, 04:03 PM   #2
Kevin245's Avatar
Sounds like freeze related swelling. Remove affected copper and replace with pex. Sell the scrap copper and buy something fun for the trailer.
Eleanor Roosevelt
Old 06-16-2015, 04:07 PM   #3
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
If the new copper fittings will not fit the old copper pipe then, like Kevin, would think that the copper is stretched from freezing. I like PEX and would replace all the copper I could get to with it.
Old 06-17-2015, 12:07 AM   #4
1975 31' Sovereign
yes, I like it!
but how to connect the PEX to the expanded copper that he can't get to?
Our AS is not a gut rehab - we're hoping to keep interior (in good condition).
A plumber friend dropped off some hardware today; hoping it works!
Old 06-17-2015, 05:24 AM   #5
Kevin245's Avatar
Originally Posted by casbc View Post
yes, I like it!
The water lines in our 1976 31' center bath Sovereign are accessible without removing interior components. Not all connections are easy to get too though. I am not sure about those with a rear bath layout that you have. Others with that layout may be able to offer some advice.
Hope things work out.
Kevin
Eleanor Roosevelt
Old 06-17-2015, 06:21 AM   #6
mimiandrews's Avatar
1966 22' Safari
Weatherford , Texas
I was able to replace all the water lines in our '66 Safari with PEX without removing the interior, except for the easily-removable parts of the gauchos. It takes some crawling around and poking your head into places, but it can be done. It's almost always possible to push the PEX into the same hole the copper pipe came out of. Use a Dremel tool or the like to cut out the copper.
I used crimp fittings, so it took a lot of planning to get that last crimp located in a place where the crimping tool had room to work. The job is really mostly head scratchin'.
I don't regret a bit of it. The system has performed flawlessly for several years now.
For sure, draw a plan of your system before you tear out the copper. There will be a few places (ours was near the water pump) where you need to re-engineer a little. Copper will make a sharper corner than you can duplicate with PEX. Back to the head scratchin' part.
Old 06-17-2015, 07:51 AM   #7
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Shark Bite. I even keep some fittings extra for emergency repairs.
Old 06-17-2015, 08:59 AM   #8
gdanderson's Avatar
1967 22' Safari
Monona , Wisconsin
Tubing/Pipe
Airstream uses copper TUBING not copper PIPE, they are two different sizes. That freezing/expansion thing is a old wives tail that will not die.
Greg Anderson
Wisconsin
gdanderson is offline   Reply With Quote
Old 06-17-2015, 10:45 AM   #9
soddy daisy , Tennessee
Tubing is measured od and pipe is measured id.
amtruckn1 is offline   Reply With Quote
Old 06-17-2015, 10:47 AM   #10
silver 67's Avatar
1967 30' Sovereign
Leavenworth , Kansas
Replace copper with pex and use shark bite fittings.
Beth and/or David
67 Sovereign, double bed, rear bath-"Moby"
2005 Dodge Ram 2500 Hemi, Quad Cab-"Ahab"
"Vintage trailer, vintage owners"
silver 67 is offline   Reply With Quote
Old 06-17-2015, 10:49 AM   #11
dscluchfc's Avatar
1984 31' Excella
Abernathy , Texas
Shark bite fittings are the bombdiggity!
David
TAC # TX-18
AIR # 410
http://www.flickr.com/photos/dsphotoscapes
dscluchfc is offline   Reply With Quote
Old 06-17-2015, 12:01 PM   #12
bellastream's Avatar
1969 31' Sovereign
Auburn , Washington
Definitely stretched copper I just had to fix several broken pipes just keep cutting off pipe further down the line until the shark bite fitting fits.
bellastream is offline   Reply With Quote
Old 06-17-2015, 12:27 PM   #13
Kevin245's Avatar
Greg Anderson
Wisconsin
Call it an old wives tale if your wish but copper tubing will swell under freezing conditions and not split . I've seen it multiple times, and I've replaced tubing as a result.
Eleanor Roosevelt
Old 06-17-2015, 01:36 PM   #14
gr.austin's Avatar
2009 27' FB Classic
Sioux Falls , South Dakota
Smile Swagging tool
They do make a swaging tool to form the end of a copper tube round and to the proper diameter. Copper does come in a 1/2 diameter which approximately 1/2" ID but is is actually 5/8 OD. They also make 1/2" OD tubing which is actually 1/2" OD. You might find this tool at a commercial plumbing outlet like Graingers. Cost is about $25 for set of 4 sizes 1/4" - 5/8". All you need is a hammer to make them work. These tools allow you to make the tube round or shrink the tube 1 size or expand the tube 1 size. Good luck
gr.austin is offline   Reply With Quote
PEX conversion from the old copper tubing gusthomasson Plumbing - Systems & Fixtures 0 11-08-2014 11:07 AM
Copper pipe and pex aren't the same size Loripep 1970 - 1973 Sovereign 7 07-18-2014 11:10 AM
Recycle that old copper pipe idroba Fresh Water Systems 1 08-03-2012 02:59 AM
Copper pipe bending and replacement of old NT30MA with new NT30SP wacnstac Furnaces, Heaters, Fireplaces & Air Conditioning 27 08-29-2007 06:40 PM
Cursing RV spokesman AYRSTRM2 Off Topic Forum 12 05-10-2006 10:47 AM
