Old 02-19-2011, 12:23 PM   #15
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Copper or PEX
Is the plumbing in the Argosy the original copper? If so there are three lines running behind the toilet. The toilet supply line along with the hot an cold for the shower. If the moisture is on top of the platform and the holding tank below the toilet is not full. I would suspect and inspect the connection for the water supply on the back of the toilet. Also check the two lines going to the shower.
Old 02-22-2011, 11:08 AM   #16
2008 27' International CCD FB
Thank you for all of your help. I did take her to my house, pluggled her in and turned on the furnace. When things thawed out I poured in RV antifreeze at all the drains and just waited with crossed fingers. Things got a little warmer so I hooked up the water and turned it on. Water spewed everywhere from the back of the toilet. But I got really lucky - all i had was a busted valve on the back of the toilet. When that was fixed we hooked it up again and tested everything which was all right. I will be much more vigilant about winterizing in the future.
dgray is offline   Reply With Quote
Old 02-22-2011, 01:43 PM   #17
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
Congratulations!
That wasn't too bad at all.
Vaughan
frozen, plumbing
frozen pipes Marklar Winter Living 19 02-06-2011 04:02 PM
