Old 06-02-2014, 05:48 PM   #1
1977 25' Tradewind
Gushing water
I need some help. I replaced hot and cold water lines from hot water heater. There are two water valves underneath the bathroom sink on 1977 AS, hot and cold. I connect the outside water supply and open both valves and water is pouring out of a drain line outside underneath the back of the trailer. Am I missing a valve to shut off and where is it coming from? Any suggestions?
turtleman is offline   Reply With Quote
Old 06-02-2014, 05:51 PM   #2
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
I believe the valves you are talking about must be low point drain valves mainly for draining the system for winterizing
Old 06-03-2014, 04:59 PM   #3
1977 25' Tradewind
Smile Gushing water
Thanks for your insight. I guess I must have been having a Senior moment. It's always good to consider the obvious. It's great. No leaks. One down and nine to go on my 10 item repair bucket list. I appreciate it. Probably will have some more problems later.
hot water water on demand with a with a normal water heater Frank's Trailer Works Water Heaters, Filters & Pumps 3 09-25-2007 12:24 AM
water pressure or water pump? 59er Water Heaters, Filters & Pumps 3 07-01-2005 04:45 PM
Water Leak above Black water tank temcotom Waste Systems, Tanks & Totes 1 06-29-2005 11:03 PM
Dual Gray Water & Dual Black Water? nvestysly Waste Systems, Tanks & Totes 5 05-09-2003 05:40 AM
Water Heater & Water Tank mgordon Water Heaters, Filters & Pumps 23 01-15-2003 06:58 PM
