Old 06-11-2016, 06:50 AM   #1
1972 25' Tradewind
dayton , Ohio
Greywater tank and thetford valve replacement
I am new to this My 72 Trade wind dump valve is cracked and destroyed can I replace it with any other brand like valterra and there was a tee after the valve where can I buy that from. I would like to add grey tank. How big, and where can I add this. can it be done from under the trailer, do I have to remove floor and install from top. Any ideas suggestions and
desi is offline   Reply With Quote
Old 06-11-2016, 02:36 PM   #2
TheGreatleys's Avatar
1974 27' Overlander
Baltimore , Maryland
If your tradewind is anything like my 74 overlander, you have a white thetford dump valve that attaches directly to the tank. You'll need to identify exactly what you have, but I was able to get a new one at vintagetrailersupply.com. The tee is probably just a 3" ABS tee, which can be found at a big box hardware store if you are in an area where ABS is allowed by code. Otherwise, VTS carries those too.
Adding gray storage is a bigger project, but most of the work is in the belly pan. You will need to route a vent through the coach and tie it in to an existing vent somewhere. I'm in the middle of doing this on my overlander. Look at my blog in the signature and you can see how I mounted the extra gray storage. Click on parts in the upper right for a list of parts I used.
TheGreatleys is offline   Reply With Quote
Bleeding greywater into black tank Ted S. Plumbing - Systems & Fixtures 40 08-17-2015 12:30 PM
I Broke the Greywater Dump Valve Handle 1Michigander Waste Systems, Tanks & Totes 10 06-26-2014 06:24 PM
1971 Cayo C-11: Adding greywater tank Jammer Vintage Kin 7 08-21-2013 04:05 PM
1969 Tradewind adding a greywater tank paul z-air Waste Systems, Tanks & Totes 0 09-12-2010 08:47 PM
blackwater/greywater tank 72 tradewind roguebrun Waste Systems, Tanks & Totes 17 06-09-2009 01:05 PM
