Old 06-05-2014, 02:51 PM   #15
PhiDor's Avatar
2007 34' Classic S/O
The Villages , Florida
Grey Tank
I think we use more water than we think and it goes into the grey tank. I am constantly telling my wife that we should use less and she has stopped replying to me. That may be a bad sign! It fills up, I dump. A lot of places allow dumping grey water on the ground. Pretty commonplace in Florida. I usually hook up a short hose to the drain cap and put it under the trailer. Leave it open and it seeps away. I also have a plug kit that fits in the campground sewer inlet so that if I don't want to use and dump the black tank, then the grey is always going down the drain. It's great on the road when the black tank isn't full and you're overnighting and just want to get rid of the grey.
Phil & Doris Drugge
[COLOR="Red"]WBCCI #4941
"Jerry and our Amazing Dream Stream"
PhiDor is offline   Reply With Quote
Old 06-06-2014, 05:20 PM   #16
PhiDor's Avatar
I added 8 gallons of water and 1 cup of Calgon Water Softener to my black tank today. 34 gallon tank. I believe that it's not the sensors going bad, but matter adhered to the sensor that stops it from doing its job.
Last night I saw this video on YouTube. Very interesting re seeing inside the black tank!!
Calgon is supposed to soften things that have hardened on the walls of the tank. I'm stubborn. I still trying.
Phil & Doris Drugge
Old 06-07-2014, 06:01 AM   #17
Gainesville , Florida
Not common anywhere I have been in Fl! Dumping gray water in most parts of the state will get you a big fine. At least that is my experience and I have lived here over 40 years. Jim
Old 06-08-2014, 09:06 AM   #18
Silver Otter's Avatar
2011 31' Classic
Nellysford , Virginia
Lin and I have had similar experiences. We do try to economize while showering and doing dishes, etc. We do use the basin-in-the-sink tactic, pouring them into the toilet when dishes are done. Even so the grey does fill up much faster than the black. To help "balance" things out we also carry a small electric "sump" pump and a length of garden hose. We stop up the shower and let the pan fill. When done, we pump the pan to the toilet through the hose. That helps us get two more days when boondocking before we just *have* to hook up and go to the dump.
Linda Heuer. President Shen. Valley Unit
Greg Heuer, 2nd VP Shen. Valley Unit
2011 31' Classic Ltd. - The Silver Otter III
2013 GMC Denali 2500HD 6.6 DuraMax - Sierra Blanca
TAC VA-18 | WBAC 1927 - Shen. Valley Unit 149 | AIR 53869
with Corey, the Norwegian Forest Cat
Silver Otter is offline   Reply With Quote
Old 06-08-2014, 09:47 AM   #19
2013 25' Flying Cloud
Rosemere , Quebec
I put dishes water in toilet, when the gray tank is full I transfer the water in the toilet with a bucket.
Christian
2013 FC 25 B
F-150 ECO BOOST
WBCCI 20130
TAC QC-2
Pitou49 is offline   Reply With Quote
Parked with full hookups and full water tank question badkat Plumbing - Systems & Fixtures 16 10-18-2013 09:32 PM
My grey water tank fills when I turn on city water m.hony Plumbing - Systems & Fixtures 36 10-25-2012 08:25 AM
Grey Water Tank Flushes Toilet (to conserve fresh water) LittleRadio Sinks, Showers & Toilets 8 03-28-2011 10:10 AM
Using a fresh water tank as a grey tank? Mike&Ali Waste Systems, Tanks & Totes 14 09-16-2010 10:50 AM
Ratio of Fresh Water/Grey Water Tank, Help! erikjware Waste Systems, Tanks & Totes 1 05-08-2008 10:42 AM
