Old 03-06-2019, 07:44 AM   #1
Newark , Delaware
Grey water tank filling from city water
Iíve got a 2016 22 Sport that Iíve had for a couple of years, but still consider myself a newbie because I havenít had any problems until now.
Weíre on our first trip of the year, just starting a 6 week trip out west but did not de-winterize until we got here in the FL panhandle. Within a half day after hooking up to city water here at a state park, the grey water tank filled up, and not by us using water in sinks or shower, we had used very little at that point. The digital level readout (always unreliable) read zero but the shower drain started gurgling when we used a sink, and the sink water didnít drain. I went out and drained the black tank first and got what seemed like the right amount out of it. Then I drained the grey tank and it flowed forever. Sinks started draining immediately. This whole scenario happened again within a day.
Since then I filled my water tank and disconnected from city water. No problem with this scenario.
Question: How is my grey tank filling from city water without using sinks or shower?
How can I fix it?
Sorry for the long post. I tried searching the forum but am limited to my cell phone here at the park.
Thanks for any help!!
bearded19711 is offline   Reply With Quote
Old 03-06-2019, 08:19 AM   #2
2018 25' Flying Cloud
Portland , Oregon
Quite the mystery! Are you absolutely sure the grey tank was empty when you hooked up to city water and wasnít overlooked in the winterization process?
daleyocum is offline   Reply With Quote
Old 03-06-2019, 09:12 AM   #3
Long Island , New York
Originally Posted by daleyocum View Post
Quite the mystery! Are you absolutely sure the grey tank was empty when you hooked up to city water and wasn’t overlooked in the winterization process?
The OP said it happened again, after draining the grey water tank.
Originally Posted by bearded19711 View Post
. . . This whole scenario happened again within a day.
bearded -- when you are hooked up to city water, have you looked carefully for leaky faucets, especially during the night? Try turning off city water at the hose bib, except when you need it. Use the water tank for flushing during the night, etc.. In other words, try to adjust some of the variables. Chances are good you will get a handle on this IMO.
Good luck,
Peter
Old 03-06-2019, 09:39 AM   #4
Newark , Delaware
Thanks for the responses! Still puzzled. Got a call in to Colonial Airstream where I bought it. The first guy I talked to was puzzled too! A more experienced person is supposed to call back. Keep your thoughts and guesses coming! Iíll let you know what the solution was when we solve it!
Old 03-06-2019, 03:19 PM   #5
Thanks for the responses! Still puzzled. Got a call in to Colonial Airstream where I bought it. The first guy I talked to was puzzled too! A more experienced person is supposed to call back. Keep your thoughts and guesses coming! I’ll let you know what the solution was when we solve it!
Are you sleeping in the trailer tonight? Try the suggestions in Post #3 . . . no need to wait for an "expert" to comment. You can become the expert for your Airstream!
Peter
Old 03-06-2019, 03:22 PM   #6
AlinCal's Avatar
1991 25' Excella
2011 19' Flying Cloud
Santa Ynez , California
The only connection between city water and the grey tank is thru the faucet, if its not running/dripping it cant happen.
This would be a serious health risk "if" someone did some creative plumbing to make it happen, not from what ends up in the grey tank but what could end up in the city supply from a cross connection.
As Peter is saying you need to verify with a few tests.
Good judgment comes from experience, and a lot of that comes from bad judgment.
Will Rogers
Alan
AlinCal is offline   Reply With Quote
Old 03-07-2019, 12:25 AM   #7
Portland , Oregon
Just had a thought. Since the trailer just came out of winterization could there be a bypass valve still open now that wasnít open before? Maybe even a valve that wasnít plumbed correctly but didnít show up previously because it was shut.
Old 03-07-2019, 10:31 AM   #8
WBCCI # 23456
2000 30' Excella
Greeneville , Tennessee
Check your city water pressure regulator. If it is set high or not functioning, you could have way too much water pressure, not available from your fresh water tank pump.
An easy way would be to install a water pressure regulator at the spigot.
jimfa440 is offline   Reply With Quote
Old 03-07-2019, 11:45 AM   #9
2017 19' International
Tallahassee , Florida
There's another person on Airforums seeking a explanation to this same problem.
WhereStream is offline   Reply With Quote
Old 03-07-2019, 12:11 PM   #10
2013 20' Flying Cloud
Westerly , Rhode Island
This is a drawing of typical AS plumbing. Two pipes go into the gray tank from the various drains and there is one vent pipe. All these pipes are large diameter pvc.
I don't see any possible way to accidentally tie in the 1/2" fresh water pex piping to a drain pipes. The only reasonable way for water to enter the gray tank is through one of the drains. I'm going with leaking faucet.
smithcreek is offline   Reply With Quote
Old 03-07-2019, 01:00 PM   #11
2018 27' Tommy Bahama
Orange , California
Gray water filling
I had the same problem last year. I accidentally used a different, smaller white hose to connect my fresh water. When i saw the dripping and filling of the gray water tank I added a water pressure valve at the source and that ended the over flow. Weird but true...
Good luck
Lucy Goosy is offline   Reply With Quote
Old 03-07-2019, 06:29 PM   #12
AlinCal's Avatar
1991 25' Excella
Good luck
When you "saw the dripping and filling the grey water tank" are you saying the faucet was dripping into the drain?
Personaly I would never leave my trailer hooked up to city water 24 x 7, especially with no regulator and no sewer connection.
Will Rogers
Alan
Old 03-08-2019, 10:02 AM   #13
Orange , California
No there was no water dripping from faucet. I think the smaller hose created more pressure. I went back to the hose that came with the AS and put a regulator on it.
Old 03-08-2019, 11:08 AM   #14
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
A hose cannot create more pressure. In fact, a smaller hose will induce a pressure drop with flow. When there is no flow, the pressure will be the same regardless of the hose diameter. It's physics.
If it is fixed, it is fixed because you added a regulator.
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Fresh water tank filling when hooked to city H2O. OffTheCouch Plumbing - Systems & Fixtures 13 03-18-2019 06:34 AM
City Water filling my tank. Milly Fresh Water Systems 16 01-11-2019 10:28 AM
city water hookup filling fresh tank? joevdb Plumbing - Systems & Fixtures 20 06-27-2017 06:17 PM
Black Tank, Grey Tank, New Tank, Old Tank Bunkroom Waste Systems, Tanks & Totes 3 07-22-2014 08:35 PM
My grey water tank fills when I turn on city water m.hony Plumbing - Systems & Fixtures 36 10-25-2012 08:25 AM
