03-06-2019, 07:44 AM
Newark
, Delaware
Grey water tank filling from city water
I’ve got a 2016 22 Sport that I’ve had for a couple of years, but still consider myself a newbie because I haven’t had any problems until now.
We’re on our first trip of the year, just starting a 6 week trip out west but did not de-winterize until we got here in the FL panhandle. Within a half day after hooking up to city water here at a state park, the grey water tank filled up, and not by us using water in sinks or shower, we had used very little at that point. The digital level readout (always unreliable) read zero but the shower drain started gurgling when we used a sink, and the sink water didn’t drain. I went out and drained the black tank first and got what seemed like the right amount out of it. Then I drained the grey tank and it flowed forever. Sinks started draining immediately. This whole scenario happened again within a day.
Since then I filled my water tank and disconnected from city water. No problem with this scenario.
Question: How is my grey tank filling from city water without using sinks or shower?
How can I fix it?
Sorry for the long post. I tried searching the forum but am limited to my cell phone here at the park.
Thanks for any help!!
03-06-2019, 08:19 AM
2018 25' Flying Cloud
Portland
, Oregon
Quite the mystery! Are you absolutely sure the grey tank was empty when you hooked up to city water and wasn’t overlooked in the winterization process?
03-06-2019, 09:12 AM
Sag Harbor
, New York
The OP said it happened again, after draining the grey water tank.
Originally Posted by bearded19711
. . . This whole scenario happened again within a day.
bearded -- when you are hooked up to city water, have you looked carefully for leaky faucets, especially during the night? Try turning off city water at the hose bib, except when you need it. Use the water tank for flushing during the night, etc.. In other words, try to adjust some of the variables. Chances are good you will get a handle on this IMO.
Good luck,
Peter
03-06-2019, 09:39 AM
Newark
, Delaware
Thanks for the responses! Still puzzled. Got a call in to Colonial Airstream where I bought it. The first guy I talked to was puzzled too! A more experienced person is supposed to call back. Keep your thoughts and guesses coming! I’ll let you know what the solution was when we solve it!
03-06-2019, 03:19 PM
Sag Harbor
, New York
Are you sleeping in the trailer tonight? Try the suggestions in Post #3 . . . no need to wait for an "expert" to comment. You can become the expert for your Airstream!
Peter
03-06-2019, 03:22 PM
1991 25' Excella
2011 19' Flying Cloud
Santa Ynez
The only connection between city water and the grey tank is thru the faucet, if its not running/dripping it cant happen.
This would be a serious health risk "if" someone did some creative plumbing to make it happen, not from what ends up in the grey tank but what could end up in the city supply from a cross connection.
As Peter is saying you need to verify with a few tests.
Good judgment comes from experience, and a lot of that comes from bad judgment.
Will Rogers
Alan
03-07-2019, 12:25 AM
Portland
, Oregon
Just had a thought. Since the trailer just came out of winterization could there be a bypass valve still open now that wasn’t open before? Maybe even a valve that wasn’t plumbed correctly but didn’t show up previously because it was shut.
03-07-2019, 10:31 AM
2019 25' Flying Cloud
Greeneville
, Tennessee
Check your city water pressure regulator. If it is set high or not functioning, you could have way too much water pressure, not available from your fresh water tank pump.
An easy way would be to install a water pressure regulator at the spigot.
03-07-2019, 11:45 AM
2017 19' International
Tallahassee
There's another person on Airforums seeking a explanation to this same problem.
03-07-2019, 12:11 PM
2013 20' Flying Cloud
Westerly
, Rhode Island
This is a drawing of typical AS plumbing. Two pipes go into the gray tank from the various drains and there is one vent pipe. All these pipes are large diameter pvc.
I don't see any possible way to accidentally tie in the 1/2" fresh water pex piping to a drain pipes. The only reasonable way for water to enter the gray tank is through one of the drains. I'm going with leaking faucet.
03-07-2019, 01:00 PM
2018 27' Tommy Bahama
Orange
Gray water filling
I had the same problem last year. I accidentally used a different, smaller white hose to connect my fresh water. When i saw the dripping and filling of the gray water tank I added a water pressure valve at the source and that ended the over flow. Weird but true...
Good luck
03-07-2019, 06:29 PM
1991 25' Excella
Santa Ynez
Good luck
When you "saw the dripping and filling the grey water tank" are you saying the faucet was dripping into the drain?
Personaly I would never leave my trailer hooked up to city water 24 x 7, especially with no regulator and no sewer connection.
Will Rogers
Alan
03-08-2019, 10:02 AM
Orange
No there was no water dripping from faucet. I think the smaller hose created more pressure. I went back to the hose that came with the AS and put a regulator on it.
03-08-2019, 11:08 AM
2002 30' Classic S/O
Fleming Island
A hose cannot create more pressure. In fact, a smaller hose will induce a pressure drop with flow. When there is no flow, the pressure will be the same regardless of the hose diameter. It's physics.
If it is fixed, it is fixed because you added a regulator.
Al
03-08-2019, 11:20 AM
2007 30' Classic S/O
Somewhere
, South Carolina
This reads like a Click and Clack Cartalk puzzler.
And the answer can only be 2!
Ok nuff of that.
Here’s my dumb Friday question idea.
During this tank filling gremlin, was it raining profusely ?
03-08-2019, 12:20 PM
1991 25' Excella
Santa Ynez
Ok nuff of that.
I miss CarTalk! Those guys were the best.
I think its the white hose that does it.
Will Rogers
Alan
03-08-2019, 02:07 PM
Sag Harbor
, New York
. . . I’ll let you know what the solution was when we solve it!
Did you hear from Colonial or try any of the earlier suggestions?
Peter
03-14-2019, 11:20 AM
Somewhere
, South Carolina
And the answer is?
03-14-2019, 12:09 PM
2019 30' International
Pennsylvania
, Pennsylvania
And the answer is?
Weird.
If you ain't havin' fun you ain't doin' it right
2017 Ford CCSB F250 XLT 6.2L Gas 4x4 4:30 rear Leer Topper Ruby Red
2019 International Serenity 30 Rear Twin
03-14-2019, 12:38 PM
Somewhere
, South Carolina
Originally Posted by majorairhead
Weird.
Not real weird. The problem from the OP has folks scratching their heads saying that’s weird.
Hoping we get an answer from OP to close the circle.
