Old 01-17-2009, 11:29 AM   #1
Grey Water Tank??
I have 1972 Land Yacht Trade Wind, 25 or 27'. When I run the sink water comes out the discharge hook up tube in the back? I have been told that Airstreams this old do not have grey tanks, and that I need a tote. but I have also heard of trailers with two tanks. How do I find out if I have an auxilary tank with a leak, or just no auxilary tank. Thanks.
Fairleigh is offline   Reply With Quote
Old 01-17-2009, 11:35 AM   #2
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
A 72 Trade Wind (25') did not have a factory installed grey tank. The water running out is normal. If you had a grey tank, you would have 2 valve handles to pull. My 75 does have a small grey tank. The black tank handle is in the rear bumper area and the grey handle is next to the discharge connection on the side.
A grey tank can be added, but a tote would be easier (and cheaper).
Richard
Old 01-17-2009, 02:19 PM   #3
tphan's Avatar
1972 27' Overlander
Longmont , Colorado
If you're up to it, you can also modify your waste plumbing to include a "T" fitting, with a valve, to divert the grey water into your black tank. You would use the black vent pipe coming out of the top of the tank.
tphan is offline   Reply With Quote
Ratio of Fresh Water/Grey Water Tank, Help! erikjware Waste Systems, Tanks & Totes 1 05-08-2008 10:42 AM
Grey water tank cover markdoane LP Gas, Piping, Tanks & Regulators 0 08-20-2004 01:04 PM
Grey Water Tank mmeburges1 Waste Systems, Tanks & Totes 1 01-09-2004 05:53 PM
No Grey Water Tank????? Anna Waste Systems, Tanks & Totes 16 11-17-2002 07:33 PM
What Grey Water Tank?? niftypkg Waste Systems, Tanks & Totes 6 09-04-2002 07:12 PM
