Old 01-22-2015, 11:30 AM   #1
1973 23' Safari
Sacramento , California
Grey Water Tank
We are looking into installing a grey water tank in our '73 Safari. We are in Northern Calif. and have been quoted a price of $2200. Any advice, suggestions, help, will be greatly appreciated.
kaminski73 is offline   Reply With Quote
Old 01-22-2015, 12:10 PM   #2
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
Contact Vinnie @ Vinnie's Northbay Airstream for a quote. He's honest and well respected in the Airstream community. Whatever figure he gives you for the work will be the right one.
2989 Wiljan Ct. Suite B
Santa Rosa CA 95407
vlamica@comcast.net
Not sure which (or any) of these #'s is still good but I'm sure you can Google and find him.
(707) 861-8116
(415) 878-7071
Bob Martel
WBCCI# 5766
Old 01-22-2015, 12:27 PM   #3
Glenritas's Avatar
1969 25' Tradewind
Shasta Lake , California
I went to RV Doctor George - Home in Sacramento and picked up a 50 Gal tank that I'm installing under the AS ahead of the axles.
Check them out and they may be able to help with the installation.
Boy talk about in your back yard . I had to travel 160 miles to get there.
Glen & Jane 1969 all electric Airstream 25' TradeWind
2014 Toyota Tundra
1998 Chevy Tahoe
2001 Casita 13' Patriot Deluxe
WBCCI #6269
My Build Thread https://www.airforums.com/forums/f11...ml#post1997059
Glenritas is offline   Reply With Quote
Old 01-22-2015, 01:17 PM   #4
robwok's Avatar
1964 26' Overlander
Richmond , Virginia
Images: 35
Find out how they're going to do it. I did my own, and dropped the belly pan, which means pulling off the axles, disconnecting the electric brakes, and then a small bit of rewiring as the wires needed to go around the tank, not over or under (or through) it. I think some shops might just cut the belly pan, and who knows how they might plumb it.
For that price, they should be doing the full monty belly pan like I listed above. Are you going to get a separate valve for the gray, or are they going to try to give you a single hookup? (single makes things easier, but not completely necessary).
I also put in tank washers when I had the tanks available. It's a cheap part and easy to do when doing the tanks initially - just make sure you winterize that if needed.
Rob.
robwok is offline   Reply With Quote
Old 01-22-2015, 02:42 PM   #5
1973 29' Ambassador
Seattle , Washington
I have a 73 with rear bath and had a 35 gallon gray tank added just behind the rear axles and it's still set up for single dump at the drivers side rear. I think it was around 1100-1400 installed (I had it done along with a lot of other work).
dcheshire is offline   Reply With Quote
Replacing black water tank with grey water tank cheetah1 Sinks, Showers & Toilets 25 10-02-2014 05:26 AM
Black Tank, Grey Tank, New Tank, Old Tank Bunkroom Waste Systems, Tanks & Totes 3 07-22-2014 08:35 PM
Grey Water Tank Flushes Toilet (to conserve fresh water) LittleRadio Sinks, Showers & Toilets 8 03-28-2011 10:10 AM
Using a fresh water tank as a grey tank? Mike&Ali Waste Systems, Tanks & Totes 14 09-16-2010 10:50 AM
Ratio of Fresh Water/Grey Water Tank, Help! erikjware Waste Systems, Tanks & Totes 1 05-08-2008 10:42 AM
