Old 01-13-2013, 11:29 AM   #1
2010 27' FB International
La Crescent , Minnesota
Galley Faucet
There is hardly any flow of water from the faucet in the kitchen. I have removed and cleaned the strainer. I have also disconected the chrome end from the extention hose. The flow from the unattached hose is good.
The trailer came without the paper work for this fixture. If any one has the model # for this faucet. I would be grateful. A drawing with how to disassemble the chrome end would also be helpful.
Thankyou!
Jay
PS. Our trailer is a 2010 27FB. International
mjayjensen is offline   Reply With Quote
Old 01-13-2013, 12:19 PM   #2
Ottawa , ON
I really don't know your trailer, but on ours, there is a filter below the galley deck that, if plugged up, could impede the flow of water.
Have you have a look down there yet?
Old 01-13-2013, 12:37 PM   #3
2002 19' Bambi
Lafayette , California
If you have left the extension hose connected, good flow from the hose without the chrome end indicates that the flow is restricted in the chrome end. I do not know what faucet you have, but many faucets today come with a built-in flow restrictor as a water-saving method. Such a restrictor could be your problem or it could even be clogged up, since the devices commonly work by having small holes to let water through.
Tim
Tim A. is offline   Reply With Quote
Old 01-13-2013, 01:00 PM   #4
Alumaholic's Avatar
1966 24' Tradewind
Albuquerque , New Mexico
Images: 33
Please Check the Aerator Again
You say you cleaned the "strainer." This terminology makes me wonder if you removed the entire aerator and cleaned all the parts and pieces besides the screen, or strainer. It really does sound like a clogged aerator. The clog is usually in the plastic elements of the aerator before the screen.
Hope this helps. Let us know how you resolve this.
Ken L
1966 Tradewind 24
2007Chevy Silverado 2500 HD Duramax/Allison
Four Corners Unit WBCCI #8654
Alumaholic is offline   Reply With Quote
Old 01-14-2013, 09:45 AM   #5
Thankyou for your input!
There is not a water filter on this trailer. When I said strainer I was incorrect. I should have said aerator. With the aerator removed the flow does not increase. With the chrome end of the faucet removed, there is good flow from the extention hose.
The faucet control has Elkay on it.
I cannot see the way to disassemble the chrome end.
Thanks, again!
Jay
Old 01-14-2013, 10:01 AM   #6
triterra's Avatar
1969 27' Overlander
1976 Argosy 28
Lodi , California
Is your faucet a Rv or a home (big box store) model and does it have only one handle? Mine (bbs) single handle has a cartridge in the main body below the handle and spigot that got debris in it. I blew air thru the cartridge and it started to work again. This has happened twice, so now I turn the bathroom faucet on first after hooking up the hose with inline filter to make sure all the debris and air are out of the line before turning on my sensitive kitchen faucet. There was a allen screw on the back side of the handle under a logo "plug". Good luck!
Michelle
69' overlander land yacht
triterra is offline   Reply With Quote
Old 01-14-2013, 10:08 AM   #7
Michelle,
It looks to me like a house type faucet. The water coming out of the extention hose indicates to me that the flow through the cartridge under the handle is OK.
Jay
Old 01-14-2013, 12:00 PM   #8
2002 19' Bambi
Elkay is a high-level brand for residential faucets, sinks, etc. so it is very possible that it has a flow reducer within the chrome handpiece. A plumber or plumbing store that sells Elkay products might be able to help you if you can't find the problem on your own.
Tim
Old 01-14-2013, 12:06 PM   #9
Alumaholic's Avatar
1966 24' Tradewind
Images: 33
Hi Jay, Please attach a picture of your faucet.
Ken L
1966 Tradewind 24
Old 01-14-2013, 02:19 PM   #10
I am having trouble attaching a picture. Where on the site can I find instructions to do so?
Jay
Old 01-14-2013, 02:22 PM   #11
murreywalker's Avatar
2013 25' FB Flying Cloud
2011 23' FB Flying Cloud
Branson , Missouri
Jay, my guess is that Elkay, like Moen, has a lifetime warranty on their products.
I suggest you call Airstream tech support (they're not all that busy right now), and have them identify your model. Then, call Elkay.
Good luck!
2013 25 FC FB (Twin)
2013 Suburban 2500
http://www.pbase.com/murreywalker
2011 23 FC FB
murreywalker is offline   Reply With Quote
Old 01-14-2013, 05:27 PM   #12
2011 23' Flying Cloud
Durango , Colorado
Murrey,
We have the same trailer, and my gallery faucet is a Moen F87254 as per page F-15 of the owners manual. I looked it up today because side spray is leaking at the chrome plastic sprayer.
Safe Travels,
Joe & Joan Donnaway
Durango, CO
JamuJoe is offline   Reply With Quote
Old 01-15-2013, 05:47 PM   #13
Here is an attempt to upload a picture of our faucet.
Jay
Old 01-15-2013, 05:59 PM   #14
Alumaholic's Avatar
1966 24' Tradewind
Images: 33
Great picture!
Replacement wands are available for that model.
If you have good flow to and through the flex line. Just go to the nearest, real plumbing supply store (Not Lowes or Home Depot) and buy a new wand.
If that isn't an option just poke around a brass welding rod, or a .22 gun cleaning rod. You just have sediment from your hot-water heater lodged in there. You may also try back flushing by forcing water through from the faucet opening back through the wand.
Ken L
1966 Tradewind 24
